Wideband A/F gauge users - Digital or Analog?
georryan
Post by georryan »
For those of you with Wideband Air/Fuel gauges, which do you prefer: A digital readout, or an sweeping dial gauge? I'm looking to get one, but I'm torn on which one to get.
I'm looking at getting the Innovative LC-2 controller with the Bosche 02 sensor. Just trying to figure out which gauge to get. I'm tempted to pick up one of those little small key sized digital readouts that I can use when I need, and stash away when I don't need it to keep my car from looking too modified.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
Re: Wideband A/F gauge users - Digital or Analog?
I got one with a digital display, my reasoning was while a dial looks cooler, the digital display was more precise and useful with a quick glance and (probably) faster to respond to change.
Post by SILINC3R »
Just go with AEM UEGO wideband and you won't look back. I've had one on each of my Subarus
bcmaxx
Post by bcmaxx »
I like my aem, digital readout and a sweep gauge, that can be adjusted to whatever psi max you prefer. and the sensor is self calibrating
georryan
Post by georryan »
I think I'm going to go for the PLX DM-6. Anyone had any experience with them? I can get one for about the same price as I can an AEM, and its expandable.
2014 Volvo S60 T5
dankberries
Post by dankberries »
SILINC3R wrote:Just go with AEM UEGO wideband and you won't look back. I've had one on each of my Subarus
+1 AEM is a sure bet. Can't go wrong with one.
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
georryan
Post by georryan »
Does the AEM UEGO have a narrowband simulation line that I can wire up to the ecu so I can just replace my stock 02 sensor?
Sent from my Nexus 5 using Tapatalk
2014 Volvo S60 T5
Post by SILINC3R »
Not sure but I know you can use it to log on a computer
Having the narrowband simulator is important IMO so you don't have to be adding a bunch of O2 bungs in your exhaust.
dankberries
SILINC3R wrote:Not sure but I know you can use it to log on a computer
+1
I use the AEM wideband hooked to my standalone for data logging/ tunning.
90 Nissan 240sx 2jz
georryan
Post by georryan »
I couldn't find out if the AEM UEGO had a narrowband output. The failsafe seemed to I believe, but it was more expensive. The PLX has the downside of having little modules you have to locate somewhere, but it seemed to be pretty good and well priced. I went with that. It also has the added benefit that I could order the boost expansion to it, so I could have the boost and A/F readings coming into one gauge. For now I'll keep them separate.
Thanks for the input guys. I'll have some updates when I get it in.
2014 Volvo S60 T5
Post by SILINC3R »
Well, post some pics when you get it installed and let us know what you think
georryan
Post by georryan »
Will do =)
2014 Volvo S60 T5
georryan
Post by georryan »
Made a new post with install pictures.
2014 Volvo S60 T5
