CJ's Prefaced 92 SS build 22T/205 Hybrid - Legawrex
Re: CJ's Prefaced 92 SS build...
Took my heads in to get resurfaced today. Got them back in less than 5 hours even tho they were fairly busy.
Pacific Engine and Machine in Tacoma off 112th and Golden Given is where I went. Great work. Cost 88 bucks out the door without a wash.
Ok so this is long over due, mostly because I'm a busy guy. BUT I finally made some more progress on my wrx swap.
I've gone back and forth on compression stuff lately and it's detoured me off and on about pistons and heads. My heads ( WRX EJ205 ) have the infamous spark plug cracks that you see on just about any head these days. It set me back mentally, but F it. I just wanna get this thing back on the road and I have bigger plans in the future.
Pistons. Well shit, this is going to be a low compression build unfortunately.... 7.51:1 to be exact. Off boost power is going to be shit, but that GT28 will pick up for that with it's tiny TD04 sized exhaust housing and being ball bearing will help as well.
I've been doing A LOT of research in the last couple weeks and I think I found my dream engine I ant to build.
I want to do an EJ22 with 207 heads.
If I can accomplish my current build, then the options are there. This build will get me closer as well.
So back to the original start of this thread, I got the heads mounted and cams and buckets and yada yada.....
Alphius
Re: CJ's Prefaced 92 SS build 22T/205 Hybrid
Post by Alphius »
What turbo coolant pipe and water crossover are those? They aren't WRX units, will they work with an under manifold inlet? I haven't followed your builds over the years so I don't know if you've used them like that before.
I think off-boost power won't be too bad, half a point of compression isn't that noticeable so it should drive similarly to a stock EJ22t off boost.
That's a 25d cross over . The pipe is a twin turbo pipe from my old motor. I just cut the tabs off of it.
Scruff_
Post by Scruff_ »
Looking good! If you need an extra hand sometime I'm more than willing to help out! Looking to get some experience, and I'm in the area :)
1991 Subaru Legacy SS 4EAT (awaiting manual swap)
1994 Subaru Legacy TW
2001 Toyota Sequoia
Thanks! What I really need is another me so I can send that one to work and I can play in the garage.. I still haven't been able to figure that out.
cj91legss wrote:Thanks! What I really need is another me so I can send that one to work and I can play in the garage.. I still haven't been able to figure that out.
If you figure that out, let me know as I could use an extra me right now :lol:
dankberries
Post by dankberries »
Coming along and lookin good! I especially like the green of course!
+1 I need like 5 of me. Kinda like that one movie duplicity? Except the other four guys can just work on my cars and not the wife lol..
Working 60hrs a week makes it hard to have anytime for cars.
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
Just a mock up.
Alphius
Post by Alphius »
Sweet! When I get my parts order from Subaru in I'll be able to start assembling my block as well. Mine will have considerably less green. Haha.
Green is fun. It'll add character.
I need to order a cam pulley tool. I've been meaning to. Just waiting on some PayPal payments.
Alphius
Post by Alphius »
If I was closer you could borrow mine. :P
I appreciate that, but I want my own. I have put so many engines together in the last year, I think it's time to invest.
I planned on buying some in the first week of this month, but my parents had present day ( they don't celebrate holidays ) so most of my recent money went to that.
Alphius
Post by Alphius »
What brand tools are you getting? I have a full set of the Company 23 tools, they are awesome. I highly recommend them. Of course, I've never used the factory tools...
I want company 23 as well.
I'm going to start with a cam tool and the crank socket.
Ordered the Company 23 Cam tool yesterday. Glad it's going to be here soon. Also have some weldless TGV delete plates coming in the mail as well as some exhaust manifold gaskets and new top feed O rings and filters.
This is getting close...
Yesterday morning I got to play with some TGV stuff. I gutted the flaps, dont need them and the tuner will delete the codes for me, or I can buy the cable and do it myself.
Here's the dumb flap that needs to go away.
Gotta drill out the screw heads, You can't just unscrew these screws, I thought it was just build up on the threads but I was wrong.
It seems as tho Subaru installs the flaps and then smashes the end of the threads as some sort of "Don't remove these" deal.
So drilling the heads off the screws and removing the threads like this is how they come out.
Flaps out. 3 more to go.
Here you can see the threads, the bottoms are smashed a little. I know you cant see it too well in the pictures but where you can see the fresh metal from me grabbing them with pliers.
Had to hit the opposite end of the rods with a hammer a couple of time to get them out.
All done!
Post by SILINC3R »
Guess it's cheaper than just buying some already done off Nabisco?
The going rate is 150-200.
The weld less kit was 69 bucks.
Alphius
Post by Alphius »
The screw ends are smashed flat to keep the screws from backing out and being ingested by the motor. Nissans for a few years had that problem, but it seems Subaru's method was smarter because I've never heard of a WRX ingesting a TGV screw. You can file off the end of the screw that's smashed and then back them out normally with a screwdriver.
Yeah I saw something about that over on nasioc, but I knew drilling out the heads of the screws would be faster. If my wife wasn't sleeping, I would have drilled out the whole screw instead of part of it and then using pliers. Priorities. ..
Forgot to mention I got an svx fwd non abs master cylinder in the mail too.
I'm excited about my progress.
Nice find on the svx fwd master. It's like a unicorn part.
kimokalihi wrote:Nice find on the svx fwd master. It's like a unicorn part.
Hold off on that, I just opened the box...
Mister Anderson
Post by Mister Anderson »
looking good, man. Your garage looks like my shop with all the Subaru's, and parts lol. The only difference is I have a ton of VW air-cooled parts along with the Subaru stuff.
91 black SS 5 speed (Canadian).... Closed deck EJ20G, fully built, V5/6 sti ra drivetrain, haltech stand-alone
93 silver TW 5 speed... rebuilt 22T with 20G heads, wrx ra drivetrain, otherwise stock.
73 kazen red VW bus riviera camper
Got my weldless tgv parts today!!!
