sunroof relay pic
sunroof relay pic
does ny one have a pic of the relay while its connected? and do i need to remove the tcu and ecu to see it so i can change it?
Re: sunroof relay pic
No, relay is near the fuel pump and horn(?) relays above the fuse panel. Sometimes you can get away with removing the kick plate and if you have them unmounted as most do. You can get enough slack to change them. If they are still mounted it maybe easier to remove the dash to get to it. That's what I would do.
i checked there and theres no red connector just brown and white and i found the horn relay its red and black
The horn relay is a bit lower than where the sunroof relay would be. You can see that in the diagram below.
http://www.surrealmirage.com/subaru/fil ... tion03.jpg
There are some pictures of the relays and their location in these pictures.
http://www.main.experiencetherave.com/s ... index.html
i fallowed those pics josh but i never seen a red connector just a brown and 2 while ones and then the red horn relay
this images must be off because i spent an hour looking for the relay. according to the scan it should be under the ignition relay and its not
Have you looked through some of the pictures I posted as well? The sunroof relay is not in the same bracket as the ignition & fuel pump relay. It's below and more than likely located where I put my extra relay for the hella horns. Are you able to find the blower fan relay?
The blow fan relay is the one on the right in this picture.
yup saw that one saw the ign relay horn and blower relay.
The sunroof relay should be in that area....I'm not sure what to tell ya....sorry.
my blower relay is mounted to a small ledge behind the fuse block
