Sweet as. By the looks the facelift 9K tacho's are 5-pin, so can be swapped into normal housings, but unfortunately the electronic speedo thing was AUDM, I've only ever seen one in NZ, and that was my mate's, and he's never selling it. Be aware the electronic clusters are backwards too, speedo right, tach left, and have their own printed circuit, so you must use the entire electronic cluster, and re-pin the plugs, and then just swap over to it what you can. I can supply a 9K tacho on its own for you if you find an electronic speedo cluster to use.PhyrraM wrote:Looking for a Post face lift Instrument cluster.
ELECTRONIC speedo, either speed scale - will be using a converter to indicate MPH.
Either tach, 9K would add a few $$$.
Either manual or automatic, can use my USDM fuel/temp gauge background to convert to manual, if needed.
So, at bare minimum, the electrical overlay, electronic speedo, and the cluster housing for an electronic speedo. Everything else I can use from my USDM stuff to make a hybrid.
Alphius wrote:OK dude, you got me with the BD/BG cluster. If you can put together a sweet package deal with the prefacelift BD taillights, the cluster and a BD/BG TMIC splitter then you've got my money. And its contributing to a good single turbo BD cause even! I know how much you like that.
Hmmmm, I'll see what I can do... Gotta be crafty with the damn post office... Have to test whether one big parcel, or a few small ones is cheaper. The rate finder on their website is fantastic, but that's not what they use in store, and you can get pinged real bad for oversize items... Bastards... Give me a few days to test some theory's and go have a chat to the post office about the method they use to charge freight. But you have a deal sir.
Btw, i'm skypable guys, my account is simply "Reuben Horsley". Pm me a time you want to chat.
