WRX Pedal Assembly?
WRX Pedal Assembly?
Will a WRX clutch/brake pedal assembly work on our cars? I know they used electronic throttles (eew), but can I get a set without the throttle and use my stock throttle pedal?
Re: WRX Pedal Assembly?
I have a set sitting here waiting to go in my car when I swap in the 5mt. The mounting looks the same as a Legacy.
IIRC, there is one or two bolts that are 'close', but not exactly the same place. The remaining 4 bolts are the same.
'02-'05 WRXs (2.0s) are also throttle cable, and the accelerator pedal should work fine.
Someperson
I have a set for sale and can confirm the 02-05s are cable throttle. They will work and iirc you may need to swap out the sensors in them
93 Winestone TW project
Thanks for the replies! It opens up my options quite a bit.
BoostedSubie
I tried putting an 02 wrx pedal assembly in my Legacy awhile back and the clutch master bolts didn't line up if I remember right.
93 Black Legacy SS
93 Legacy
97 Green Outback
97 Red Legacy GT
99 Black Legacy GT wagon
93 Legacy
97 Green Outback
97 Red Legacy GT
Well damn...
Someperson
Bolts are slightly off, can make it work w/ a dremel
For the sake of future searches, What bolts/holes are off, The Clutch Bolts only, or are the bolt holes for the brake booster off as well?Someperson wrote:Bolts are slightly off, can make it work w/ a dremel
Someperson
I'll ask sqc151 cause i forget which 2 are off. But 2 line up and 2 are off i want to say it was the clutch side that were off...
Yep I'm doing it, Almost 2 year bump.
I have that awful screeching sound every time I push in my clutch. I need it gone.
Has anyone got some photos or solid information before I commit to buying a newer pedal set?
Spray some lube up in there? There is a big spring assembly that helps with the clutch kickback. If you push your seat back all the way, or remove it, it's pretty easy to get into. I bet you it's just caked with crap.
I could do that, but that would be too easy.
Maybe I was just using that squeeking as an excuse
