Everything was working great this morning, both low/high beams. On my way home I noticed both the low beams were not working. The high beams still work fine.
I checked the bulbs, they don't appear visibly broken, and passed the continuity test.
Every fuse in the car passed the continuity test. Swapping the twin relays for L/R headlights did nothing. The parking brake indicator on the dash turns off at the correct time, meaning that that sensor should be fine. Main problem is that there is no 12V coming to the low beam wire.
I will be deciphering wiring diagrams in any case, but just wanted to see if anyone had any suggestions
