converting awd 5mt to fwd by bolting on rear section fwd 5m
Can you convert an awd 5mt to fwd by bolting on the rear section fwd transmission to it. I am needing to replace my fwd 5mt and was told that this may be any option.
RoughDiamond
Re: converting awd 5mt to fwd by bolting on rear section fwd
Iirc, you need the shorter main shaft as well, so basically you're tearing apart both trans to cobble one together... I'd just find the same type and swap it in..
1991 Legacy SS (BC) EJ22T // 4EAT // Pewter Metallic (Sold)
1991 Legacy SS (BC) EJ22T // 5MT // Rio Red (Sold)
1991 Legacy SSRS (BC) EJ20G (Full COP and AWIC Swap) // 5MT // White Pearl Tri-Coat Africa Rally replica in progress.
If I'm not mistaken the FWD trans has a different final drive ratio also
91 ss Ej22t dohc td04 sti Slanty haltech elite 1500
Yes, the FWD does have a 3.7 final drive vs. either a 3.9 or 4.111 in the AWD.
I'm gonna go on a limb and say no-one has attempted this, at least on this site.
Final drive would be irrelevant (if it's possible), since you aren't matching to a rear diff. Unless the point of the exercise was to get the tallest gearing possible.
But, and here's some more speculating, if you could swap an awd to fwd, you could swap over the 3.7 FD ring and pinion over as well.
I read that first post wrong I thought he was trying to convert it to awd.
86BRATMAN wrote:http://www.914world.com/bbs2/index.php?showtopic=104513
That's pretty impressive!
There are kits available to do the same, but they aren't cheap.
that's awesome! I wanted to do this glad to know there is a walk through and kits.
