Post facelift EDM glass headlights for ’92-’94 Legacy. Both left and right work perfectly-- including vertical and horizontal manual adjusters. Includes untested motorized vertical adjusters.
Left side was damaged when I got it. The horizontal adjustment was broken and the reflector was loose inside the headlight. Someone had tried to use a drywall screw to hold the reflector in place. I disassembled the light, repaired the pivot point and reassembled. I broke off a rusted screw taking apart the horizontal adjustor, but after repairing the gear inside it works great. Everything works normally on this light-- remaining damage from the previous owner's drywall screw does not interfere with proper function. It's solid, functional, and adjustable in both vertical and horizontal directions.
Right side is in great condition with a repaired horizontal adjuster gear.
$OLD
RIGHT:
LEFT:
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
Price dropped AGAIN. Post here or message me if you have questions about the condition or the repairs I made. These are fully functional and ready to light up your life. You'd be a fool to drive around with USDM plastic headlights on your car when this set of headlights is available at such a bargain price!
-steve-
03 Legacy L Wagon
