I have a 1993 Subaru Legacy L with 252K miles.
I am having a very slow oil leak on the passenger side leaking on the metal piece above the control arm (?).
I already replaced the PCV valve, valve cover gasket, and gromets about a year ago with OEM parts installed by a mechanic.
The steering pump has been rebuilt and is no longer leaking as it did before.
I also checked the oil sensor behind the alternator and it does not leak.
Could the gasket still be leaking? I am unable to see where the leak is coming from underneath the car.
Thanks in advance!
- Brian
Update
![Image](http://img.photobucket.com/albums/v696/brisky86/IMG_20151204_143937_Area_Circled.jpg)
![Image](http://img.photobucket.com/albums/v696/brisky86/IMG_20151204_143952.jpg)
![Image](http://img.photobucket.com/albums/v696/brisky86/IMG_20151204_144026.jpg)
Here is the oil sensor (looks clean)
![Image](http://img.photobucket.com/albums/v696/brisky86/IMG_20151204_144012.jpg)
