RckyMtnLegacy's 93 Turbo...On the Road Finally!
dankberries
Re: RckyMtnLegacy's 93 Turbo...EJ20G swap in progress!!
Post by dankberries »
Sublimejoe wrote:
RckyMtnLegacy wrote:So I have read every electrical thread on the EJ20G ecu. What's the best place to start, should I do the converter or COP conversion? Which is the best to read to get this thing started up
I am also interested in the answer to this question. I dont even know what you mean by COP conversion or convertor. :/
COP refers to "Coil on Plug" meaning, as offered in some variants of the ej20, that for each spark plug their is an individual coil that resides atop of it(4 total), with 4 individual channels at the ECU .
The ej22/t utilizes a wasted spark setup with a single pack the resides on the top of intake manifold with 4 plug wires lead to each spark plug, and has 2 channels at the ECU.
The conversion would be going from wasted spark to COP.
My recommendation, if you have the time and money, you should make the COP conversion, as it is said to offer better spark.
Their are several good write ups on here with how-to explanation.
93 impreza rally muffin
89 Nissan 240sx sr20
90 Nissan 240sx 2jz
RckyMtnLegacy
Post by RckyMtnLegacy »
My plan was to do the COP but is that the only wiring I need to fix. I know I'll need to extend some as well but ECU wise?
1990 2.2l Legacy--RIP
Keeping the Legacy's Legacy
Official Subaru Ambassador
RckyMtnLegacy
Also got some more items
Sublimejoe
Post by Sublimejoe »
Ahhh, ok I see. Its been quite some time since I read about it, but from what I remember (which is spotty) if I were to swap over the original intake manifold from my EJ22 I wouldnt have to change the wiring from the harness. Am I mistaken?
What does the COP conversion entail?
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
Sublimejoe
RckyMtnLegacy wrote:Also got some more items
Nice! I took my pedals out of the box yesterday, I need to clean them up and paint black. How much of a pain was it to install the pedal set?
Parts Needed:
Manual Cluster
RckyMtnLegacy
Pulled brake pedal last night. Going to try install tomorrow night. My last has a business trip for The next 4 days so I'm trying to get as much done as possible.
RckyMtnLegacy
Boom pedals are in
They were a pain but it helped to have the full dash and column out.I loosened the harness on top that is ran under the cluster pulled it up and put a pipe under it to keep it from falling while I pushed up on the pedals to line up the mounting bolts. I did get every bolt to fit though
Had a helper too
Good looking pup! Yeah I prefer to swap pedals with the column unbolted. Makes life so much easier. Sorry you didn't make the middle of the month finish goal.
RckyMtnLegacy
Ya I still firmly believe I could have got her running by then but we decided a couple hours ago that we didn't want have to do anything twice so we are going to do the COP conversion now and clean up the engine bay and paint it black instead of trying to clean it up later just to get it to the show.
Installed Whiteline Ball joints
Started ECU fun too
Thanks Kimo on the connectors and crumpets highly recommend
Almost ready to get this under the car too. Ordered some Motul too.
Which tranny is that? I hope you don't need an engine hoist to move it about ;)
RckyMtnLegacy
Regular 5 speed. I was draining it, plus I was sick of lifting it every time I needed it moved. The 4EAT on the other hand is a beast
Sublimejoe
Nice! I was considering putting the trans in by itself before I get the motor in, good idea or bad? Also reminds me I need a new crossmember because mine broke.
Parts Needed:
Manual Cluster
RckyMtnLegacy
Floor jack will make it much easier
Sublimejoe
Cool, so thats not a bad idea? Figured I could get the tranny in and do everything needed for five speed swap before I put the motor in.
Parts Needed:
Manual Cluster
RckyMtnLegacy
Nope not bad that's what I'm doing
Way easier to install engine when tranny is in place.
Sublimejoe
Awesome, wish someone here lived near me in Virginia.
Parts Needed:
Manual Cluster
RckyMtnLegacy
Another full day
mike-tracy wrote:l love the look of a clean block. I always let degreaser soak in and hit it with my pressure washer, but yours looks much better than what I can do. What's your secret?
mine
http://bbs.legacycentral.org/viewtopic. ... 32#p418232
A parts washer works well and then I usually will hit any stubborn areas with brake cleaner.
Awesome work on the car!
RckyMtnLegacy
Thanks. Just looked at wiring for ECU, COP, and transmission swap... Long nights ahead and not my cup of tea
RckyMtnLegacy
Cleaning up my harneses
Ordered a set of could from SubieLandImage
Sublimejoe
Awesome! Jealous!
Question, I cant seem to find the shift linkage/shifter assembly anywhere. What exactly do I need? Maybe I am looking in the wrong place or something.
Parts Needed:
Manual Cluster
RckyMtnLegacy
As many of you can see my due date passed and she is unfinished. I decided to not cut any corners and do it right the first time. I hope to finish by the end of June. Show was this past weekend and was interrupted by snow. My buddies and I still got together and talked shop. Got to see each other's builds.
I brought her instead to the show
Oh Shit, a 750? That's seriously cool!
