LINK ECU
ciper
Post by ciper »
They are fairly cheap here, a board member could sell them. What is the length of the lead between the bosch coils and the plugs?
MY92
Post by MY92 »
250mm
John
http://www.cardomain.com/ride/560635
ciper
Post by ciper »
Found a discussion about these and the guy mentions paying 240$ including leads, that would be in australian dollars right? http://www.mrtrally.com.au/forums/topic ... IC_ID=1910
Here is one speaking about replacing them as soon as possible
http://www.mrtrally.com.au/forums/topic ... IC_ID=4855
another
http://www.mrtrally.com.au/forums/topic ... IC_ID=3510
MY92
Post by MY92 »
Yep OZ dollars.
John
LegacyT
Post by LegacyT »
Is this ECU plug and play, meaning it uses the factory wiring harness? I understand that once its in it needs to be tuned. How much does it cost?
Mark,
ciper
Post by ciper »
It is plug and play for the overseas legacy. For us a minor rewire is most likely needed. Im waiting on these answers because I may use the same ECU. Either that or wire in one of the common WRX ECU so that any tuner could help me out. One big question is wether this will drive a waste spark system like the standard link ECU's.
MY92
Post by MY92 »
The plug in Link can handle waste spark.
As for plug and play, it pretty much is, except for the map sensor, that is the only wiring you have to do.
John
georryan
Post by georryan »
Well we don't have a map sensor, so that is solved, unless you were refering to the MAF?
resstiboy: you have a 2.2l? Did you overbore your engine?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
MY92
Post by MY92 »
The Link uses a MAP sensor instead of the MAF sensor to read airflow.
John
rsstiboy
Post by rsstiboy »
no I don't have a 2.2ltr, we don't overbore here, we have stroker kits available to us here, 2.2ltr and 2.4ltr.
the problem with my spark is that it tends to blow out under boost, its probably due to the length of time they were sitting on the halfcut out in the weather, and the fact that they are now 10 years old.
A guy in sydney here has SUBSTANTIAL mods to his RS and runs a 2.2ltr block, MY98 heads, turbonetics 550HP turbo, and external wastegate, he uses these coils and has been running them on 23psi for 3 years without drama.
thats good enough reason for me.
I just ordered a USB LINK cable so I can now tune it via laptop, fast and the furious style, the idiots tuning my car can't use the hand controller
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
rsstiboy
Post by rsstiboy »
I can't beleive you don't have MAP sensors on your cars? how does your boost cut work? we have both MAP and MAF sensors on ours.
georryan
Post by georryan »
Yeah the 95's and on up have the MAP sensor, but we don't. I found this out by buying some little dohicky from ebay that basically is a timing advance "mod." I would advise everyone to stay away from those little mods. This one was more reputable than most, though (in my defence). haha
It required a MAP sensor to work, and after doing some research I found out that we didn't have one. The MAF may have some extra wires than yours that collects the extra information that that your MAP uses for the boost info. I seem to recall something about that, but I'm not that knowledgable about it.
Other guys know more of the specifics of how the boost cut works.
2014 Volvo S60 T5
Legacy turbos do have MAP sensors, just like Liberty RSes.
MY92
Post by MY92 »
The Gen1 Legacy has a MAP sensor which is used for boost control and a MAF for air flow.
John
boostjunkie
Post by boostjunkie »
georryan wrote:Yeah the 95's and on up have the MAP sensor, but we don't. I found this out by buying some little dohicky from ebay that basically is a timing advance "mod." It required a MAP sensor to work, and after doing some research I found out that we didn't have one.
I think I remember your post back in the day about this piece. I believe you are in fact, confusing the MAP sensor for the Intake Air Temperature (IAT) sensor that is non-existant on our cars. I remember a lot of those ebay chips worked by modifying the IAT signal.
georryan
Post by georryan »
My BAD...your totally right Boostjunkie. I feel dumb. Good call. This whole time I was thinking IAT not MAP.
2014 Volvo S60 T5
ciper
Post by ciper »
NA early legacy have a atmospheric pressure senser inside the ECU and an air flow sensor.
Later NA legacy have a pressure sensor on the right side shock tower and an air flow sensor
Turbo legacy have a pressure sensor on the shock tower with a two position pneumatic switch that allows it to measure either atmospheric or after turbo pressure. They also have the air flow sensor.
Now knowing that, is this any different that the Liberty RS?
MY92
Post by MY92 »
Sounds the same as the JDM/OZ RS/GT's.
But as I said, the Link uses a bosch map sensor to measure airflow so the MAF becomes redundant.
John
ciper
Post by ciper »
I swear I read that the link has a choice between the two type of air flow sensors, the possum link is meant to be "plug and play" so couldnt it use the stock MAF?
rsstiboy
Post by rsstiboy »
possumlink relies on a MAP sensor, infact i'll be removing my MAF for better airflow
ciper
Post by ciper »
On the link plug in module page" Sometimes the complete installation can take place without lifting the bonnet. Uses 100% factory sensors."
On the subaru specific page
"with mapping for up to two Bar (29 lbs) of boost using all factory sensors"
What did I miss?
LegacyT
Post by LegacyT »
If this truly is plug and play ( or even almost, by that matter) then I think I'll have to get me one of these. Price anybody?
Mark
Just for completeness' sake, ciper, non-turbo models with both a pressure and airflow sensor do also have the pressure exchange solenoid.
MY92
Post by MY92 »
I'm sorry, I give up now.
John
ciper
Post by ciper »
LegacyT: I also want this for its plug and play. Nate from S-squared offer to sell me a plug and play haltech which I still need to research.
