45 degree airbox with a td04
ride_child
so im swapping these into my wagon im building and im kinda wondering if anybody has done the same or if not, what would be some ideas of how to deal with the intake between the two... im just looking for ideas at this point.
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
'91 Black SS - SOLD
Re: 45 degree airbox with a td04
This is what I had a shop fab up to use with the 45 deg. airbox.
http://main.experiencetherave.com/subar ... install/13
The bottom part of the airbox has to be modified slightly and the metal intake piece doesn't really allow easy removal so I have to remove the four bolts holding it to the airbox to remove the airbox or anything related to the intake. You could partially eliminate this issue by cutting off or trimming the tab off the bottom of the airbox that the top part of the airbox hooks into before you secure the clips.
Here are some more pictures
http://main.experiencetherave.com/subar ... install/09
http://main.experiencetherave.com/subar ... install/10
Wait a sec...Where's your MAF? Glad I stumbled across the pic of the awic inlet hose with the stock BPV. I finally sourced a stock one for free and would like to ditch the HKS I currently have. The vacuum nipple on my old one broke off several years ago.
I no longer have a MAF because I am using a stand alone setup for speed density.
