Swap a NA to turbo.
alex-svx
Swap a NA to turbo.
Post by alex-svx »
Hello.
I have two wagon and one is NA and i have tear down a turbo wagon. But now i have find a very nice sedan.
And i have a friend that told me if i should swap the sedan and not the wagon to turbo than i need the wiring diagram for a sedan one. Because the ground wiring and taillamp won't fit direct. Is this true?
I dont think the wiring inside the car is different from a turbo than a NA one. I know i need the engine wiring but this i have form the wagon. :)
Thanks.
Re: Swap a NA to turbo.
If all you are looking to swap over is the engine then you should be able to just use the turbo engine harness and associated turbo component (MAP sensor, wastegate solenoid, & pressure exchange solenoid) harness.
The body/chassis wiring differences won't matter.
alex-svx
Post by alex-svx »
Thanks :D
