Master cylinder ?
icrman
Master cylinder ?
Post by icrman »
So are there huge differences between manual and automatic transmission applications? This is for a 93 Legacy. I see listings for 4 X4 and manual vs automatic, and abs or not.
This is a non abs non 4x4 car with automatic.
So will the manual trans one work? And what are the differences between them all? Thanks.
Pntaste4evr99
Winestone Cowboy
Re: Master cylinder ?
Post by Pntaste4evr99 »
Should work, or at least I would assume it would work fine??
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
originalcyn
Post by originalcyn »
Weird. I have a 93, and i thought that the options were abs and non abs.
Kijan
1993 Legacy LS | PBM 227
There is a difference between abs & non-abs, but there also can be (doesn't necessarily mean there is) a difference between manual & automatic because of the hill holder system.
https://i.sli.mg/MNbKBw.jpg
I believe this is integrated into the master cylinder on the manual trans cars. However you should be able to use the manual master cylinder on an auto car and the hill holder just wouldn't be hooked up if it's there at all.
