Miss Fire Cylinder #3
thatsme87
Post by thatsme87 »
On my Subaru with the 2.2 liter engine it has a misfire on cylinder number 3 the only code it's throwing is a misfire on cylinder number 3 when the check engine light is flashing it seems to do it largely while trying to go up a hill are between 25 and 35 miles per hour otherwise I don't seem to notice it much any thoughts on this would be awesome
Re: Miss Fire Cylinder #3
What year and model do you have?
What work have you already done or checked?
thatsme87
Post by thatsme87 »
It's a Subaru Legacy with a 2.2 liter engine in it I have bought an engine with 44000 miles from Japan Crated engine and had it installed by a shop I haven't checked or done anything it's supposed to have new plugs new wires
Is this a 1st gen legacy? Auto or manual? What check engine codes come up when you check? Is it possibly the PWR light instead of check engine?
thatsme87
Post by thatsme87 »
So the check engine light flashes when it's missing but the only code it shows is a miss fire on cylinder #3 no other information shows up on the scan tool from autozone. It's a four door coup legacy not sure what you mean by gen. Automatic transmission
What year, and is this a US model legacy?
