RckyMtnLegacy's 93 Turbo...On the Road Finally!
Re: RckyMtnLegacy's 93 Turbo...EJ20G swap in progress!!
We have crank!!! No start though
1990 2.2l Legacy--RIP
Keeping the Legacy's Legacy
Official Subaru Ambassador
Damn so rad! Make me a harness please <3
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
Manual Cluster
Don't get too excited I can't get it to run yet. Still trying to figure out spark.
Time to hit the garage for some diag trees. Haven't used one since college.
Getting the correct voltage fluctuations from cam and crank sensors. Cam voltage at ecu but nothing it getting to the ecu from the crank sensor. Harness for crank sensor is a mess and looks like shit.
This is my weakness
You might want to consider running a new shielded wire set.
Could I run it straight from the connector to the ECU and delete the stock crank sensor Harness?
Threw up a little, sorry
Same here. I stripped all the tape from the harness connector back into the main harness and found all this. How do I repair it with shielding?
How does the wiring check out back to the ECU? Does it all have 0 ohms or are there issues?
If there are issues, then the easiest thing to do would be to use some new shielded wire to the ECU to replace the run of wire from the ECU to the crank sensor connector.
Between the connector and the ecu harness I get no continuity at 4 and 5 but at 6 (ECU) I get 0 ohms between it and #3 of the connector which is correct but I get resistance at #6 (ECU) from 1 and 2 of the connector so the wires are touching where they shouldn't be.
Yes that will work.RckyMtnLegacy wrote:http://www.alliedelec.com/belden-8451-0 ... DQodkxAETA
Would this work for the wire?
Based on your last post I'd just replace the existing wire with this. I think that'll be the easiest route long term.
Wired it in and still just cranks
Quite the journey with this car... just went through all 19 pages seeing everything you have endured and done. Nice work sticking with it!
I'm looking through a JDM ecu link it to see what's wrong today
What's the word man! How'd it go today?
Parts Needed:
Manual Cluster
Manual Cluster
Nothing. Going to try and find cam and crank sensors to try that since we are not getting the "correct" signal according to alldata
Checked timing, checked crank sprocket, checked cam sprocket
So you still aren't getting the correct signal to the ECU from the crank & cam sensors?
Only able to check with voltmeter but it seems like I'm not. Barely gets a 10mv fluctuations
Hoping to get a scope at work to test
Ok, yeah keep us posted.
