Code 17 injector 4
Code 22 knock sensor (replaced still there)
Code 23 air flow sensor
Code 24 air control valve
Code 35 canister purge solenoid valve
Code 45 pressure sensor and exchange valve.
Now the car runs fine for most part. Every once in a while I will get a small fuel cut under full load for a split second every once in awhile but it runs fine. Car has 197k and no prior history on work done.
Any ideas where to start? I have put anew knock sensor in and nothing. I've cleaned iacv with sea foam and nothing. Clean maf sensor... Car doesn't feel like a turbo car but can hear a small whine of turbo when under load, but nothing like the Wrx's I've owned over the years.
