EJ22T Piston part numbers
SubaruLegacy43
Hello everyone, I'm in need of some help. I'm trying to locate factory sized "B" EJ22T pistons. My local dealer has located the correct part numbers, but cannot get the pistons themselves. They will not share the part numbers and most places online do not specify what size, either A or B, that they are. Does anyone know the part numbers for both the left and right set of B pistons are? Thank you very much!
duluthsound
Re: EJ22T Piston part numbers
Part Number: 12013AA241SubaruLegacy43 wrote:Hello everyone, I'm in need of some help. I'm trying to locate factory sized "B" EJ22T pistons. My local dealer has located the correct part numbers, but cannot get the pistons themselves. They will not share the part numbers and most places online do not specify what size, either A or B, that they are. Does anyone know the part numbers for both the left and right set of B pistons are? Thank you very much!
Not available from Subaru of America
Sent from my A0001 using Tapatalk
SubaruLegacy43
I looked this number up and it gave me only the right set of non turbo pistons. I'm trying to find the lower compression turbo ones. Thanks a lot!duluthsound wrote:Part Number: 12013AA241SubaruLegacy43 wrote:Hello everyone, I'm in need of some help. I'm trying to locate factory sized "B" EJ22T pistons. My local dealer has located the correct part numbers, but cannot get the pistons themselves. They will not share the part numbers and most places online do not specify what size, either A or B, that they are. Does anyone know the part numbers for both the left and right set of B pistons are? Thank you very much!
duluthsound
Oh you're right...let's see here
duluthsound
12018AA340 Mark A
350 Mark B
360 Mark C
All standard size
350 Mark B
360 Mark C
All standard size
SubaruLegacy43
Awesome! That's what I needed. Thank you so much!duluthsound wrote:12018AA340 Mark A
350 Mark B
360 Mark C
All standard size
duluthsound
You're welcome, if you ever have any other part number/availability questions feel free to ask.
SubaruLegacy43
I really appreciate it. So for the Right piston set in B size is 12013AA350 correct?duluthsound wrote://uploads.tapatalk-cdn.com/2016123 ... b4e2c1.jpg
duluthsound
Correct, left and right according to the catalog.SubaruLegacy43 wrote:I really appreciate it. So for the Right piston set in B size is 12013AA350 correct?duluthsound wrote://uploads.tapatalk-cdn.com/2016123 ... b4e2c1.jpg
SubaruLegacy43
Awesome awesome. This was the last piece of the puzzle lol. Thanks a bunch!duluthsound wrote:Correct, left and right according to the catalog.SubaruLegacy43 wrote:I really appreciate it. So for the Right piston set in B size is 12013AA350 correct?duluthsound wrote://uploads.tapatalk-cdn.com/2016123 ... b4e2c1.jpg
