No more 2.2L (updated: Now image intensive)
WRXish
Re: No more 2.2L (updated: Now image intensive)
Ok, I am really confused about the IACV information. I just dropped a 25D into my 91 wagon that came from an automatic 98 outback legacy so which IACV do I use? The one from the 2.2 is available and since I am using a 2.2 ecu that seems to be the most sensible approach. But I already have the new IACV I bought for the 98 25d mounted up...so which way to go?
Is the IACV the three wire rotary IAC valve or the newer style IAC valve (stepper valve) on the throttle body?
