Portland, OR ISO EJ20G FUEL RAILS
YetiSmasher
I need some ej20g fuel rails asap! This is the last step in my build. If anybody has some leads please contact me
robertpaige
Re: Portland, OR ISO EJ20G FUEL RAILS
What injectors are you using? If they're greytop 440's, 92-94 NA legacy rails work and they're plentiful in the junk yard
If you're using yellow 550 STi side feeds, 90-91 NA legacy rails will work. As well as EJ25D rails.
He's got a dohc manifold
YetiSmasher
Exactly. I was able to source some in Vancouver, but the previous owner had cut the end where the FPR is. Now I have to figure out how to weld a new flange on.
Do you have any places local that make stainless steel braided lines? A shop like that will likely have the equipment to braze a new flange onto your fuel rails.YetiSmasher wrote:Exactly. I was able to source some in Vancouver, but the previous owner had cut the end where the FPR is. Now I have to figure out how to weld a new flange on.
YetiSmasher
Got everything hooked up. Hopefully I'll be firing her up today
