Ej22E to EJ20G Swap
Ty92leg
Ej22E to EJ20G Swap
Post by Ty92leg »
Hey guys, I have a 92 wagon with the ej22e, 5mt and I think its time for a new engine.. I have been doing some research about possible swaps. I see a lot of ej22t to ej20g swap info and "guides," but I am not familiar with the legacy ss. Is the swap similar or should I go with a different rout? Thanks for any advice in advance :D
Re: Ej22E to EJ20G Swap
Welcome to the BBS.
The swap should be similar. There will be little differences and things that need to be done, but I can't think of any show stoppers. The main difference will be the ignition and having to rewire things for coil on plug vs. wasted spark.
Ty92leg
Post by Ty92leg »
Okay great! That shouldn't be too difficult. Thank you for the info. If I do find myself stuck somewhere I know where to ask.
nortonjefferson
Post by nortonjefferson »
Dont forget to acquire the turbo related sensors! (map, pressure exchange etc). If you plan on putting a different turbo specific transmission in, you will more than likely also have to go to a hydraulically actuated clutch. Doing this same thing as we speak, just a 22t instead of a 20g. Good luck!!
White 1993 L Wagon AWD 5MT-FXT lift, 27” MTs 380xxx miles
White 1991 L sedan AWD 5MT-(Robtune 550 DOHC Ej22t swap coming together) 187xxx miles
Black 2005 LGT 5MT-Ej20x swapped daily, VF40/elh
PhyrraM
Post by PhyrraM »
Don't forget the front crossmember.
Sent from my SM-N900V using Tapatalk
Pntaste4evr99
Winestone Cowboy
Post by Pntaste4evr99 »
Don't forget the turbo lol
94 Winestone SS 5MT Rob 550 20g. (Pickle)
Original WA car with 460k miles and climbing
