Outback Struts on a 93 Legacy
Legobrick92
Post by Legobrick92 »
I have been without a Subie for a while and just got a 93 Legacy sedan that I'm wondering about putting Outback struts on to lift it some. I'm getting older and it's hard to get off the floor these days (lol). Any suggestions?
WRXish
Re: Suspension Sticky Compilation Thread
Post by WRXish »
Legobrick92 wrote:I have been without a Subie for a while and just got a 93 Legacy sedan that I'm wondering about putting Outback struts on to lift it some. I'm getting older and it's hard to get off the floor these days (lol). Any suggestions?
hire a young mechanic? :mrgreen: :lol:
WRXish
Post by WRXish »
Hey I'm an old man too and struggle getting up and down too....welcome to my world :-)
Abeall2
Post by Abeall2 »
I have figured out 93-01 Impreza coilovers should fit 90 legacy. Can lower it an inch. I have been looking at the Godspeed ones. Mono SS. Seem legit and kind of affordable. Also I want to stress I am NOT advertising for anyone. Just trying to find a quality product for my 1st gen. I almost got banned for posting links in the past. The image thing never works for me. Thanks in advanced
90 AWD,5MT,Legacy w/ Ej22t swap.(Silver)
94leggy
Post by 94leggy »
Abeall2 wrote: Wed Feb 28, 2018 9:12 pm I have figured out 93-01 Impreza coilovers should fit 90 legacy. Can lower it an inch. I have been looking at the Godspeed ones. Mono SS. Seem legit and kind of affordable. Also I want to stress I am NOT advertising for anyone. Just trying to find a quality product for my 1st gen. I almost got banned for posting links in the past. The image thing never works for me. Thanks in advanced
So if I bought gf suspension it would be a direct swap to my bj platform?
Re: Outback Struts on a 93 Legacy
What year and body style first gen Legacy do you have and plan to swap the 93-01 Impreza suspension to?
There are some differences in ride height and damping rates. I think the wagon may be more affected. Additionally, you would need to match FWD to FWD components and AWD to AWD
arse_sidewards
Post by arse_sidewards »
Legacy777 wrote: Tue Apr 06, 2021 6:49 pm Additionally, you would need to match FWD to FWD components and AWD to AWD
Only in the rear and even then it's only the knuckle and strut itself that are affected. You can't put an AWD strut on a FWD knuckle because they interfere with each other.
1992 FWD MT wagon, 1994 AWD AT wagon
wtdash
Post by wtdash »
OB struts will bolt-up fine on front; rear top hats/strut mount bolt pattern is different. If you swap top hats you'd need to confirm the springs match as they were tapered in there somewhere.
It's been done often enough that you can find (better) specifics on a Google search and other Subie sites.
Edit: '98-'08 Forester struts also work....look at my first try at it...when I was just a SubieNewb: https://www.ultimatesubaru.org/forum/to ... with-pics/
And note the only response! Thanks again JC!
GL,
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
arse_sidewards
You can re-drill your rear towers for the forester top hats. I forget which one is taller but the forester and legacy top hats are different. Also 1st gen bolt pattern is different than 95-99 (rear only, front is compatible). If you intend on further lift I would strongly consider drilling your rear towers to use the 2nd get or Forester bolt pattern since off the shelf spacer lifts are still available for those.
Abeall2
Post by Abeall2 »
I ended up doing AGX gas adjust struts and then used newer wrx coil springs and stock top hats. It was difficult but i got the perfect stance, almost seems stock but did have to roll the fenders (lowered) about 1.5”
