There is another about an hour away from me, and 3 or 4 two hours away in Richmond, but I figured I'd check with you guys since it may be a while before I get get out of town.
Im looking for:
A/C belt tensioner & pulley assembly
Both sun visors or at least the passenger's. That one is broken off/missing and the driver's has loose upholstery and wont stay up all the way. Is there a way to tighten them up?? I prefer grey but any color will do.
The P-R-N-D-3-2-1 piece for the shifter assembly, mine is missing. I go by the one in the instrument cluster, but I don't want crap falling down in there since its wide open.
A trunk latch assembly with a good light switch, or just the switch if it can be removed. It looks like somebody went to town on the latch with a tire iron, destroying the light switch in the process...!
Trunk lift tension rod - one of these is broken, and I know shipping this might be pricey, so I may hold out to find one around here.
Any other parts that are good to have spares on hand, or anything that makes for a sweet upgrade for the interior
Thanks!
