Burning up MAF's
martimus919
Burning up MAF's
Post by martimus919 »
I'm getting pretty burnt out working on this car of mine.
I've swapped an EJ22t into my 90 Loyale and have been having an issue burning up MAF sensors. It seems to be getting worse, and I'm running out of sensors. I'm guessing it's in the wiring trim I did, like not enough grounds or something but I'm not exactly sure.
Looking for any suggestions or tips, I really want to start driving this thing again.
07 Outback XT VF52
94 Legacy Sport, VF23, 550 RobTune, various other things
93 Legacy Touring Wagon EJ205 management and dash swap (in progress)
90 Loyale Turbo, EJ Turbo Swap, 2" lift
82 Brat, EJ22 swap, RX AWD trans w/ LSD rear, 5 lug 4 wheel disc.
wtdash
Re: Burning up MAF's
Post by wtdash »
you've checked the Voltage @ the MAF wiring? Probably could use a resistor (?) to lower to the 5V or whatever it should be. What does Wiring Trim mean? Merged harness?
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
martimus919
wtdash wrote:you've checked the Voltage @ the MAF wiring? Probably could use a resistor (?) to lower to the 5V or whatever it should be. What does Wiring Trim mean? Merged harness?
I get battery voltage at the MAF sensor and have 5v at pin 5, and I also have a good ground.
As far as the harness trim, I simply trimmed the Legacy harness down to just the engine related wiring. I did not merge the harness (wish I did though).
07 Outback XT VF52
Are you still having issues with MAF's?
martimus919
Legacy777 wrote:Are you still having issues with MAF's?
Yes, I haven't really done anything with it over the winter. But one thing that I did not mention before that I think may be related is that my fuel pump howls, sometimes it goes away. But I thought it was the factory pump so I upgraded to a Deatschwerks pump and still howls. So I'm wondering if it's not just isolated to just the MAF, but that the MAF is just the weakest part.
07 Outback XT VF52
Hmmm, that's interesting about the howling fuel pump. If you've replaced the pump, are you sure it's the fuel pump that is howling?
martimus919
Legacy777 wrote:Hmmm, that's interesting about the howling fuel pump. If you've replaced the pump, are you sure it's the fuel pump that is howling?
Oh yeah, it is quite clear where the noise is coming from. Once I put the upgraded fuel pump in it's hard to not notice anything else. I replaced the fuel pump thinking it was going bad and to double check the feed lines for blockage. I just found that nothing was wrong with either.
07 Outback XT VF52
martimus919
Well, I made a new discovery today. I found that when I pinch off the IAC the car will idle. Thinking I had a bad IAC I swapped it out to find the same results. I'm wondering If maybe I have bad wiring perhaps. I'm going to test the continuity of the wiring to see if wiring has been damaged.
07 Outback XT VF52
Are you saying that if you pinch off the line supplying air to the IAC valve the car will idle ok? Does it not idle when you don't pinch off that line?
martimus919
Legacy777 wrote:Are you saying that if you pinch off the line supplying air to the IAC valve the car will idle ok? Does it not idle when you don't pinch off that line?
Exactly right. However, it would not drive well. I could make it up my drive way and into the garage in low range but it was a bit of a struggle. So I tested the wiring for the IAC and found everything to be in good shape. Frustrated I started over with my diagnosis. Do I have spark, yes. Do I have fuel, yes, but... When the fuel pump primes I get 40-45 psi, and then instantly drops to 0 psi. With these results I determined that pinching off the extra air for the IAC will allow it to run with the limited fuel supply.
So my new direction is fuel pump wiring and new pump. With the swap I used the factory wiring and relay. I found that my ground for the fuel pump had melted the casing a little bit and I remember the relay ran warm. I'm thinking of now just running a wire straight to the fuel pump and grounding it to the body after I replace the fuel pump and see if I'm still getting a loud whine from the fuel pump after bypassing the factory wiring.
07 Outback XT VF52
If the fuel pressure doesn't hold then I would look at the regulator. Fuel pressure should stay up after the pump is primed. Based on my logs from my Link ECU, fuel pressure was at 43.5 psi with the key in the ON position and engine not running on initial startup. The fuel pump primes like to stock ECU and then shuts off.
Have you modified the fuel system at all?
martimus919
Legacy777 wrote:If the fuel pressure doesn't hold then I would look at the regulator. Fuel pressure should stay up after the pump is primed. Based on my logs from my Link ECU, fuel pressure was at 43.5 psi with the key in the ON position and engine not running on initial startup. The fuel pump primes like to stock ECU and then shuts off.
I installed a DeatschWerks 255 fuel pump but other wise nothing else has been changed. Last night I put a factory pump back in and found the pressure to be holding around 30-42 but still having trouble getting the engine to run without crimping the IAC inlet tube. So I'm thinking fueling is not the issue and maybe the aftermarket pump does not have some type of check valve.
07 Outback XT VF52
Does your throttle body have this little needle valve screw in it? Do you know if the throttle plate/stops have ever been adjusted? Have checked/tested the TPS sensor's idle switch?
Have you checked all the wiring from the MAF and other sensors back to the ECU to verify they have 0 ohms / good continuity as well as verify they are not shorted?
martimus919
I went ahead and made a new harness and replaced the old one. Car started right up and has been running pretty well. I still need to wire in the VSS wire, I keep getting a code for that after a little bit of driving. The other night when I got home from work I did notice the fuel pump had started to whine like before. I have some suspension and steering concerns to address as well so I've decided to park it for a little bit while I order parts.
I'm wondering if possibly my alternator is putting out too much and in turn damaging the wiring? I have a 90 amp two wire alternator from a late 90's legacy/outback wired into the body's harness. I'm curious if if my "conversion" was not wired properly or if maybe I just need an external regulator.
07 Outback XT VF52
I have a similar 90 amp HO alternator and it's fine. Have you checked the voltage? If so, what is it outputting?
martimus919
Legacy777 wrote:I have a similar 90 amp HO alternator and it's fine. Have you checked the voltage? If so, what is it outputting?
Last I remember I have 14v at the battery and am also reading on the dash.
07 Outback XT VF52
That is a normal and regular voltage, so I don't know if I'd say that's your problem.
Out of curiosity have you checked the 5v reference voltage going to the MAF from the ECU? Maybe that is high or low.
