Joe's 93 RHD Legacy Wagon Build
Re: Joe's 93 RHD Legacy Wagon Build
Sure, why not. You better be running a fmic, or a tmic mounted vertically, to catch all that wind from running no hood
One of those will work for me. I just want it to run, so whatever I can do temporarily even to make that happen. What kind of pipe would I need to get for that intake setup?
Parts Needed:
Manual Cluster
Front & Rear bumper Chrome Trim
Manual Cluster
You'll need to measure the inlet on your turbo to figure that out. It's possible someone on the BBS has posted what aftermarket intake they used on their SS/TW
im running the apexi power intake system with a 45 degree airbox, its the tits!!
Kris
'91 Mica White SS - R.I.P.
'91 Black SS - SOLD
'91 Black SS - SOLD
Radical! Ive been looking around on eBay a bit and found this. In order to use, would the only additional part I need be the 90 degree elbow?ride_child wrote:im running the apexi power intake system with a 45 degree airbox, its the tits!!
https://www.ebay.com/itm/JDM-SUBARU-WRX ... rk:40:pf:0
Parts Needed:
Manual Cluster
Manual Cluster
I could also just buy this right?
I cant tell if that is where I mount my maf sensor though.
Parts Needed:
Manual Cluster
Manual Cluster
That hole in the lower pipe is where you mount the 02-07 MAF sensor. Your maf is a big ol' tube, so it can't be made to work without an aluminum welding shop. I'd really recommend searching to see what people on here successfully used.
This is what Ride_child is talking about:
https://www.ebay.com/itm/JDM-95-Subaru- ... :rk:1:pf:0
But instead of using the silly filter, he used an NA intake box I think?
Look here, told you people on the board have done what you're doing. They go in to what adaptors are needed, and the links still work.:
https://www.bbs.legacycentral.org/viewt ... =1&t=53417
Ok, its all coming together. I definitely don't have anything that looks even close to this, if this is indeed the MAF I need:
From there I can either buy the Apexi filter that is linked which is said to bolt on to MAF, or I can buy adapter and buy another type of filter. Is that correct?
Then I should just need the 90 degree elbow right?
Parts Needed:
Manual Cluster
Manual Cluster
Yeah. Just make sure you check in with the parts you're looking at before you buy
What would you do personally, buy that oem maf and adapter/filter, or buy the damaged Apexi that you linked and repair?
Parts Needed:
Manual Cluster
Manual Cluster
The apexi comes with the correct MAF included, so it's a better deal
I knew I could count on you, Mike Tracy. Merry Christmas!
Parts Needed:
Manual Cluster
Manual Cluster
In the linked thread, you could buy this adaptor to bolt to the maf in the apexi kit. Then you could use any aftermarket 76mm cone filter, and chuck the broken apexi one:
https://www.ebay.com/itm/AFM-Air-Filter ... 1642098418
Alright, I purchased the Apexi intake! Now I need to get a 90. I checked out the sticky thread with info on where to get the OEM part. Should I be going that route or is aftermarket fine? It looks like the OEM piece has a couple of spots for hoses to connect to, so Id imagine those are probably pretty important right?
Parts Needed:
Manual Cluster
Manual Cluster
Yeah. I do have one in my for sale thread
Oh well damn, Ill buy that one! Ill PayPal you now!
Parts Needed:
Manual Cluster
Manual Cluster
if you want pictures or details of my setup, just let me know. and yes i used the NA intake box, you just have to get some longer bolts to bolt the bracket into the frame rail
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
I looked through your thread a bit, it definitely helped seeing pictures. I don’t have the air box, any brackets or anything else really so I’ll have to make something. I appreciate you guys helping me.
Parts Needed:
Manual Cluster
Manual Cluster
thats just the stock airbox and bracket from an n/a impreza, should be pretty plentiful in a pick n pull!
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
Radical! I am gonna try to make a trip to the yard soon.
Yesterday I rewired the turbo sensors that I need to run to ECU. I didnt fully understand when I did it the first time, so this time I made only one of the wires long since the other one is just for power.
I also received my intake:
Parts Needed:
Manual Cluster
Manual Cluster
So that's for a stock turbo with a 90 degree inlet. You can get a silicone 90 to put on the front or make a friend with a tig and skills to weld on a cast 90, which I have one I can send you for shipping haha I was going to do that to a td04.
Are the manifolds for the under mani intake the same as the ones with the 90 degree inlet turbos?
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
Good thing silicone 90s are cheap!
Im not sure about that last part honestly
Parts Needed:
Manual Cluster
Manual Cluster
Kris, he's using a stock ej20g manifold, hence using the stock 90 + silicone 90* bends.
word, i was just double checking cause i couldnt remember off the top of my head! i clarified in a pm.
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
joe, where are you located at again? im going to be in the southeast for spring break 2019, if im close enough we should meet up!
Kris
'91 Black SS - SOLD
'91 Black SS - SOLD
