Robtune 550cc
JimBos Legacy
Robtune 550cc
If I were to run 550cc Top feed injectors, instead of running the adapters for the yellow top side feed injectors, would the 550 tune still work? I found some 550cc top feed injectors online awhile searching around
JimBo
1992 JDM Subaru Legacy GT wagon
Re: Robtune 550cc
I don't think the injector latency (dead) times are going to be the same between the side & top feeds. If you can find that information about both types of injectors you could clarify that.
Are you planning on using a different intake manifold? If not I think fitting the top feeds on there would take a lot of work.
JimBos Legacy
Re: Robtune 550cc
I read somewhere that too feeds would work on the stock fuel rails without the adapters. Maybe I read wrong. Phase 2 adapters seem to more commonly available then I thought. Probably would end up being easier to get the yellow tops and adapters.Legacy777 wrote:I don't think the injector latency (dead) times are going to be the same between the side & top feeds. If you can find that information about both types of injectors you could clarify that.
JimBo
Re: Robtune 550cc
Top feeds will not work on the first gen Legacy fuel rails.
What adapters are you thinking of using?
JimBos Legacy
Re: Robtune 550cc
One of the kits I found is by a company called Deatschwerks, haven’t looked around the fourms to see if any one else has used them.Legacy777 wrote:Top feeds will not work on the first gen Legacy fuel rails.
JimBo
Re: Robtune 550cc
That kit is for the Newer Subaru manifolds. I don't know if they would be a direct fitment on our cars without some work.
JimBos Legacy
Re: Robtune 550cc
I’ll take a look at the injectors and see if it looks like it’ll bolt upLegacy777 wrote:That kit is for the Newer Subaru manifolds. I don't know if they would be a direct fitment on our cars without some work.
JimBo
carfreak85
Re: Robtune 550cc
The tune was developed with a specific set of hardware in mind. Deviating from that exact list of parts is a gamble I would not be interested in taking.JimBos Legacy wrote:If I were to run 550cc Top feed injectors, instead of running the adapters for the yellow top side feed injectors, would the 550 tune still work? I found some 550cc top feed injectors online awhile searching around.
1975 Superstar Wagon
1984 GL-10 Turbo-Traction Wagon & Hardtop
1987 & '87.5 RX coupes
1987 RX Type-RA
2002 WRX sedan
2019 Outback 2.5i Limited
1987 RX Type-RA
2002 WRX sedan
JimBos Legacy
Re: Robtune 550cc
That’s why I’m thinking I’m going to go with Robs adapters that he sells, he mentions that deatschwerks work aswell, but are a bit more pricy.carfreak85 wrote:The tune was developed with a specific set of hardware in mind. Deviating from that exact list of parts is a gamble I would not be interested in taking.JimBos Legacy wrote:If I were to run 550cc Top feed injectors, instead of running the adapters for the yellow top side feed injectors, would the 550 tune still work? I found some 550cc top feed injectors online awhile searching around.
JimBo
Re: Robtune 550cc
What intake manifold do you currently have, Jimbo?
JimBos Legacy
Re: Robtune 550cc
I don’t have the exact part number, but it’s the stock manifold on a V1 Ej20Gmike-tracy wrote:What intake manifold do you currently have, Jimbo?
JimBo
Re: Robtune 550cc
Ahh. all you need to do to use phase 2 sidefeeds is ej25d (all years, 96-99) rails. I know you were talking about retrofitting top feeds, but Rob's conversion kit does the same thing as using ej25d rails on an ej20g manifold.
JimBos Legacy
Re: Robtune 550cc
Gotcha, so it’d probably just be easiest to run robs adapters. I can’t seem to find the ej25d rails anywhere, but maybe I can find them at a junk yard somewhere around heremike-tracy wrote:Ahh. all you need to do to use phase 2 sidefeeds is ej25d (all years, 96-99) rails. I know you were talking about retrofitting top feeds, but Rob's conversion kit does the same thing as using ej25d rails on an ej20g manifold.
JimBo
