Performance:
Walbro 255 with sock, 25k miles $40
V2 STI top mount intercooler, with hose, factory scoop and duct, plus factory (V4 I think) water spray tank SOLD
MSD Coil (new in box) for neon plus neon connector with pigtail ready to wire in $40
Hallman Pro RX boost controller SOLD
Joe P boost controller $20
Mishimoto oil separator setup: SOLD
Autometer z-series boost gauge mounted in dash vent w/some hose and wiring (may be willing to sell just gauge and plate) $60
AEM wideband setup with all wiring, sensor and gauge. Have original box, hardware, and custom steering column pod SOLD
Full exhaust setup: SOLD
Add-on harness for BCS, pressure solenoid, and MAP sensors (I built this when I went NA to T) with sensors $20
5sp shifter (I think from WRX but was in my Legacy), w/kartboy front bushings, I rebuilt whole thing years ago, still tight, w/spring and pins $40
Kartboy WRX rear shifter mount, never used $15
Kartboy WRX outrigger bushings, never used $20
Rear diff bushings (for JDM WRX?), aftermarket (forgot brand), never used $20
WRX STI motor mount pair: SOLD
Group N pitch mount $25
WRX coolant tank w/some brackets I made to put in a Legacy $30
WRX TMIC, black plastic one, w/cheap aftermarket cast inlet fittings, no hoses $40
Stock stuff:
N/A EJ22 ECU (1994) $15
N/A EJ22 injectors (red 1994, 170k miles) $15
1994 ECU plugs clipped from car (3 of them) + chassis harness pieces (good for scavenging wires) and relays/misc $20 grab bag
1992 SS center caps, good shape $10
1994 blue center console trim w/inner and outer boot (rear two clips are broken but worked fine for me $20
PN 047105166 screw X3 (I think these are to attach fuel filler neck to car), new in bags $5
Impreza dash mounted compass (single DIN screen) with bezel and some wiring, no sensors, I never got to use/test it $40
Stock MAF (I think EJ22T) $10
Pioneer head unit/stereo (single DIN) w/wiring for Legacy, and 1.5 DIN storage compartment (OEM subaru) $50
2002 Forrester fuel filter NIB $10
Stock fuel pumps, I think 1 turbo and 1 NA, with misc parts $10
Drivetrain:
Spec clutch setup for NA trans with custom made disc and stock FW, 25k miles $150
5 Speed Trans converted to RWD (from 1995 legacy L), worked great $300
5 Speed Trans from another Sport Sedan: SOLD
5 Speed Trans from Forrester, possible blown center diff $20
Later outback limited slip diff and axles (will check ratio) $100
Extra driver’s fender: SOLD
Extra turbo two-piston front brake setup (centric rotors, akebono pads), make offer
Walbro $40
MSD Coil $40
Joe P MBC $20
Dash with boost gauge $60
NA to T sensor harness $20
Shifter $40
Kartboy shifter mount $15
Kartboy outrigger bushings $20
Diff bushings for JDM wrx $20
WRX coolant tank $30
WRX TMIC $40
NA 1994 M/T ECU $15
Wiring grab bag with harness plugs and leads $20
NA Injectors 170k miles $15
Center Caps $10
Shifter Trim $20
Fuel neck screws? $5
Dash compass $40
MAF $10
Stereo and storage bin $50
Fuel Filter $10
Stock Fuel pumps condition unknown $10
Spec clutch setup for NA trans $150
