thanks for all the help,
Aaron
Looking around I have been able to find a set of 15" from a 95 with 55 offset all around, the 90's had 50 upfront and 55 in the back. Can I get away with this difference? It seems like the 15" won't be too big of a deal. Pretty cool wheels " https://www.ebay.com/itm/263986232990?ul_noapp=truejefferson wrote: ↑Sat Nov 23, 2019 5:25 am I'm pretty sure the stock offset is 55, and yes lighter wheels do make a difference. You might check out the stock wheels that came on the ss, but they are 15 inch instead of 14 and that would probably add some weight. I'm also not sure how the weight compares between steelies and the aluminum wheels. I just replaced the stock wheels on my Tribeca with forged sti wheels and saved about 8 lbs per wheel. The stockers are horribly heavy. It made a very nice improvement.
