Got a set for sale in Lakewood, Wa 98439
Description in second post.
CJ 253 332 8158
20R Twin turbo heads. Lakewood, Wa
Re: 20H Twin turbo heads. Lakewood, Wa
Still got em. Lowered the price to 300.
Ive got a set of low mile Twin turbo heads from a JDM Subaru Legacy GTB. These work with the phase 1 electronics, Turbo legacy or anyone who is working on a 20k sti swap. Early 90s basically. These heads flow just like the 20k Sti heads, just have a different cam profile, not as aggressive as the 20k sti cams. These would be great paired to a 22t block, Pretty low compression and great for high boost. Last set I had on my 22t had plenty of power at 18 psi.
I got these as partial payment for labor I did on a friends wrx. I cant use these on any of my cars because I have switched to later electronics. They are missing a few valve cover bolts. Those are easy to come by, any 25D will have them. There are plenty of extra shims for the buckets for getting the valve clearances right. I also have some 25d fuel rails to include, You just gotta get the hardlines from a 25d. Also included is 4 New Cam seals. Intake manifold pictured is also included.
Re: 20R Twin turbo heads. Lakewood, Wa
Hey there, I'm having a possible head issue with my leggy wagon. What else would i need to make this all work if i purchased these from you? Also, any idea what shipping would cost to the Denver, Co area?
Check out the dohc unspoken details thread in the engine sticky section. Tons of info there!!!
Still for sale.
