a little teaser thread *pg7 new goods^
subaru_styles
Re: a little teaser thread *pg6 new photos^
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
1994 turbo wagon
subaru_styles
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
Purty!
subaru_styles
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
Nice!
subaru_styles
yeah i have been double checking the wire diagrams between usdm and edm. though the plugs on the back of both heater units are completly shapped different there is a 2nd intermediate plug on the edm unit before the dash harness. as long as my car has the same secondary plug it should go in right there, if not...re-wire time
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
IronMonkeyL255
Re: a little teaser thread *pg7 new goods^
Where'd you find that hvac unit? I am super jealous.....
Rio Red '91 Legacy SS
You can get them on ebay uk or germany I believe.. Question is, does it hook up to the usdm hvac box properly? I want one with no ac. I think the base models had them here in the us.
subaru_styles
well i dont have time right to to see if my stock usdm hvac has the second harness between it and the cars wirring. if someone can chime in that would be great.
i know as far as edm cars go, there is also a base model control that uses a manual selector, instead of electronic.
anyway i know it may be difficult to compare as most of the wires are just "color" labeled, but here's the diagrams for my stock one and the new replacement
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
IronMonkeyL255
Looks like it's close, but one wire that ties in to the wire going from the fan switch to the blower motor resistor on the european one (pin 12) isn't there, and there is a wire that goes to the blower motor relay on the USDM one (pin 10) that isn't there on the EDM one. That pin on the motor relay is just grounded on the EDM one. If you can get some shots of the connector on the unit, i may be able to figure out if it will fit and the wires seem to match up. I believe the secondary harness is just like the secondary harness in USDM '91 models. I got the switch plate out of a '92, and the secondary harness becomes obsolete, leaving the main harness to plug straight into the switch plate (I believe, but I haven't had a chance to get it put in because I'm lazy).
subaru_styles
ill take some pics up tomorrow..i noticed the minor ground difference, but wasnt sure if its because one has an "off" button , and the other uses a "0 speed" on the fan selector
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
subaru_styles
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
IronMonkeyL255
That connector is much bigger than the one on my '92 board. It may be the same as the '91 connector, in which case you could probably use that harness adapter thingy. I'll check it out, and maybe even throw my '92 piece in and have the harness off mine available for experimentation.
subaru_styles
so , basicallly the usdm cars don't have that 2nd white connector?
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
IronMonkeyL255
Can you get a pic of that white connector unplugged? '91 had a larger connector similar to either the white or yellow one on that unit. This plugged into another connector which I believe is the same as '92-'94 (need to get mine in to say for sure). If I am correct, you would plug your harness into the '91 pigtail, then either into the unit, or the pigtail off of there. I will try to get it tore down this weekend to get some more info for you.
Yes, the 90-91's had that pig tail. Here are some pics from my car.
http://www.main.experiencetherave.com/s ... ages/hvac/
subaru_styles
haven't updated this
jdm bumper beam and fogs installed + the lip painted
found some nos yellow chargepseed mirrors
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
Do you have the JDM oem anti static pads yet?
subaru_styles
i dont think that was an option when the gen1's came out. I am however tracking down the oem electrostatic air purifiermike-tracy wrote:Do you have the JDM oem anti static pads yet?
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
Is there one specifically for our cars, or does the newer kit fit?
subaru_styles
no, but its a pretty basic piece that could easily be put on
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
Yeah I'm gonna do that too! Thanks for the idea. The antistatic kit i mentioned above looks like it could be fitted to any subaru. I'm sure you've seen this, but for reference: http://northursalia.com/modifications/i ... tatic.html
subaru_styles
ok I'ts waaaayyyy overdue. I disappeared for awhile, but plan on being back on the bbs (ya i know fb killed the forums). Ill give this thread an update & changes with the car.... as soon as I find out where to host pics now!
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
subaru_styles
Re: a little teaser thread 2022
ok so ill try to list some of newer changes:
interior:
-swapped out to recaro sr4 raptor trial seats
-jdm kenwood double din deck
-jdm kenwood rear deck speaker pods (color is near spot on to abm)
-swapped out to efeil shift knob
-jdm rs momo steering wheel
-jdm full size spare. jdm roadside kit & jdm car cover
-rear bulk gaurd (not installed yet)
wheels:
-Prodrive GC-05a 17x8 et40
exterior:
- finally was able to get a nos jdm rear glass installed.
interior:
wheels:
exterior:
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
Looks good man!
I really need to spend some time on my Legacy....even just to drive it....been way too busy.
