It hadn't been driven for some time due to bad head gaskets causing it to overheat. I found a swollen and burst turbo coolant feed hose. I trimmed it and attempted to drive it home. It also had a bad alternator, but I cannibalized one off my '90 Legacy I bought just a month prior. The coolant hose was completely toast, so she was trailered home. Cost: 2 cases of Rainier.
Here was the actual reason it was "overheating". A bad turbo coolant feed hose. A bit of coolant hose later and she was purring. Now, she does smoke, A LOT. The valve cover seals are rock hard and the water pump is leaking. Other than that she was driving as well as an automatic can. That's the downside to this car, a 4EAT. I don't like old automatics. That will change in time.
