For reference and comparison sake: I have a full 3” exhaust, stroked 2.2T using the wiseco pistons. I’m running an AWIC with a larger than stock frozen boost radiator and larger than stock water lines. I’m also running a VF23 turbo. The heads are stock other than being converted over to roller rockers. The cams are stock.
Rob’s 550 tune is set for 18 psi on a 2.0 liter with a 16G turbo I believe. With my car having higher displacement, SOHC, and a different turbo, I haven’t dialed in the safe maximum boost levels. It can safely support more boost than I have been usually running.
The last time I had it on the track I was running right around 16.5 psi of boost and I was watching the MAF voltage. I was getting close to 5v when stretching out 4th gear.
When driving to the dyno I noticed some knock indication from the check engine light (rob tune feature) in lower rpms. Maybe it was picking up a rattle in the engine bay because WOT over 3.5k didn't seem to pick up anything. But out of caution, I lowered the boost a bit and put in a can of octane booster to see if it would help.
One thing I recently realized is that when I purchased the tune, I had told Rob that wiseco states the CR for their hybrid stroker build was rated at 8.5:1. I’ve recently been doing calculations for head gaskets for the RS-RA heads on the 2.2T stroked block and realized that the wiseco calculation is based on the motor using 2.5 DOHC heads. So with our stock heads, the CR is actually closer to 9:1 or a little more. If you are running stock heads with this stroker setup, just be aware of that. My goal was to get a baseline, not find the maximum power this setup can achieve. I’m hoping to run the same boost on the DOHC heads once I’m done to see how the power curve changes. Still, I thought the numbers would be good to have to see how a different setup might perform or affect things.
I did one run at 13.5 psi of boost and two runs at 15psi. I did my pulls in 3rd gear starting at 3k rpms.
I forgot to look at the MAF voltage so when driving home I tried do a pull on the freeway in 3rd gear and see where the voltage sat. I was able to see it sit at around 4.6v so I’m pretty confident that is just about what it was seeing during the dyno run as well.
Ultimately I ended up running 234 hp and 277 ft lbs of torque. The motor seemed to get the peak torque in the mid 3k range, and the peak horsepower right around 5k.
