I've got a 91 SS with a leaky oil cooler, obtained replacement parts but having difficulty figuring out the correct routing from the coolant pipe and hose configuration to the oil cooler itself. Photos would be extremely helpful.
Whoever worked on this before me rigged it with a longer hose and had it routed underneath the exhaust, where it hangs down and can catch on things. I've tried getting the parts from Subaru to line up and I can't seem to understand how it's supposed to route.
I found the parts diagram on here already, that was a big help in identifying and obtaining the parts. I sourced the O-ring from some other place as Subaru doesn't carry it anymore, but at least they had the dimensions listed on the parts sheet.
Does anyone have photos of how the oil cooler actually routes / looks when installed with the piping and hoses in the correct place? Where does the bracket on the hard pipe bolt to? I could not get that to line up with anything.
