1993 Legacy SS won't rev
superstock2
Post by superstock2 »
Car starts and runs okay, idle is a little low. Under WOT the car will rev and then hit a wall around 4-5k rpm. The car revs better when given partial throttle and under load in first gear the car barely runs at all. I replaced the maf (not OEM, Delphi) and am wondering where to look next. The gas tank was also pressurizing quickly. Any thoughts are appreciated.
93' Legacy Sedan w/ Full SS swap
arse_sidewards
Re: 1993 Legacy SS won't rev
Post by arse_sidewards »
Revs great until it doesn't sounds like a fuel issue.
1992 FWD MT wagon, 1994 AWD AT wagon
Are there any codes in the ECU?
