Turbo Legacy owners with aftermarket turbos please read
MY99 2.5GT
I haven't seen any type of FAQ or information forum specifically made for turbo legacy owners with upgraded/aftermarket turbos.
So if you have a turbo Legacy or an EJ22G in your car with an upgraded/aftermarket turbo please post the following here:
1. What model aftermarket turbo do you have
2. What aftermarket intake and exhaust piping do you have
3. Intercooler Yes / No
4. How well does your aftermarket turbo fit that piping or how well does it fit your stock piping if thats what you have
5. What boost level are you consistently running
6. What model boost controller are you using
7. What EGT, A/F readings are you getting at those boost levels
8. What other mods did you have to make in order to compensate for the extra flow and boost
Your contribution of information and experience is greatly appreciated. It will definitely help myself and others as they plan to purchase a combination of parts to mod their turbo legacy or EJ22G.
Brad
Brad
eastbaysubaru
MY99 2.5GT
Matt Monson
- quasi-mod-o
WARNING:
read further at your own risk
Pissing match in progress
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
boostjunkie
I think he's talkin about this:
www.sqc-ny.com/tech/turbos.pdf
The page notes that the mitsu turbos have different exhaust widths, or something along those lines.
Brad, if you ever want to take a look at my setup, let me know.
The biggest issue I have right now is the sizing of my injectors. Right now I'm running them at 100% IDC. Not good. But I've been trying to find a true drop in replacement. No such luck. Kelly, mentions the use of nissan injectors, but I have my doubts as to whether they're true DROP in replacements for the stockers.
MY99 2.5GT
Thats cool.91White-T wrote:It says EJ22T right on the id plate under the hood.
Totally not what this thread was meant for. But please see this link for background information regarding the Turbo Legacy's engine designation: http://bbs.legacycentral.org/viewtopic.php?t=15132
Anyway I was looking for specific combinations that people are using on their turbo legacy or other EJ22G equiped cars. I thought it would be nice to put as much information as possible in a single thread for easy access and good reading. Please follow that purpose in your post.
Thanks Jason and Matt for your info. Jason I am still researching the fuel rail swap for a more available selection of injectors for fitment in the stock manifold.
Brad
boostjunkie
MY99 2.5GT, you might want to try taking a look for another post in here (maybe someone else can help me figure out which post exactly) where vrg3 modified a stock n/a legacy fuel injector to possibly flow more . . . similarly to a modification done on the nasioc. A couple people were thinking of having those injectors flow benched at RC engineering, altho I don't know of what came of that.
Supposedly, the modification will close to double the flow of the injector, and if the stock inejctor's rated at 270-280cc, that would be somewhere in the neightborhood of a 450cc injector (I'm speculating). The saving grace in this mod is that the n/a 2.2L fuel rails swap into the ej22g with minimal effort.
In MY99 2.5GT's defence, I call the turbo legacy block an ej22g as well, just because it has some very similar characteristics to the ej20g, and IIRC, they were produced at arond the same time.
Who knows?
Who knows?
MY99 2.5GT
That would be so sweet since I have a perfectly in tact 2.2 NA fuel rail. Let me know when you find out about this mod.
ciper - I guess my 95 Impreza with an EJ22T motor ready to go in isn't in my profile. I'll refer to it as an EJ22G/T so as not to confuse anyone here:)
91White-T - Their Depends, get it right
MY99 2.5GT
I know what will fix this. The BLOCK alone is referred to as an EJ22G. A complete engine with all the items attached is an EJ22T. See the difference? We are all running EJ22T while the WRX guys (for example) are using EJ22G blocks.
Do you mean current mods or planned? My engine is still on an engine stand, the heads are at a machine shop and the other parts are in the trunk of the donor car.
The modifications on the recieving car are extensive though. I dont drive it as often, I usually drive my sedan to work. Probably the most interesting modification that is taking place at the moment is a high quality head job on the stock EJ22T heads and conversion to roller rockers.
Here is an old thread but with lots of my info. I should update it.
http://bbs.legacycentral.org/viewtopic.php?t=14314
eastbaysubaru
I have the set of modded 92 NA injectors and I did offer to send them to RC for testing if anyone wanted to pay for it. I emailed RC asking how much it would cost and what I would need (since the o-rings don't look so great), but haven't heard back. If anyone does want to pay for the testing I'll call up RC to find out.
Or when the weather's warmer, I'll just make my own ghetto DIY flow bench to test them with. And hope I don't blow myself up. :)
On-topic portion of the content: Matt's right that the exhaust side shouldn't be a problem, and that the compressor outlet differs, but you should also be aware that turbos meant for 1997 and later model years also have a different compressor inlet. The stock Legacy Turbo compressor has an elbow bolted to it pointing straight up; later ones don't have that bend and instead have the intake tubing go under the passenger side intake manifold runners.
Sure what do you want to know?MY99 2.5GT wrote: 91White-T - Care to talk about the experiences you have hadwith your mods?
PS Don't take me too seriously, I was jokin around earlier...
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
MY99 2.5GT
Honestly I really appreciate you guys and the information I find here. Its good to joke around every now and then.
I will be starting over piping wise with my setup since my engine simply came with the intake and exhaust manifolds and no up pipe, or intake piping. I don't really like the WRX idea of having the intake run underneath the manifold so I may try and jimmy my own little fitting to route it up and around. I need to take some measurements once I get it in the impreza to see what will fit.
Brad
Brad
legacy92ej22t
1992 White Legacy Sport Sedan 5mt turbo
Removed snorkus, K&N filter
Saab 900 TMIC. I plan to cut in my WRX hood scoop this spring to help it breath better.
Diamond coil pack.
Joe-P MBC set at 12.8 psi on stock VF11 for now with plans to run 14-15 psi once I have a FCD. I hope to run a TD05-16G or VF23 in the future.
OBX Type R Turbo gauge 30-0-30 vac/boost. (Total piece of crap! I need an Autometer
C.E.S. Racing Systems "street" 3" turbo-back exhaust with DP03 ceramic coated twin dump down pipe and BEP (Boost Enhancement Plate).
I'm not running an EGT or A/F gauge yet so I can't help there.
Diamond coil pack.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
FrmRgz2Rchz
1. What model aftermarket turbo do you have?
TD05
2. What aftermarket intake and exhaust piping do you have?
stock exhaust, modified intake with stock box
3. Intercooler Yes / No?
Saab 900
4. How well does your aftermarket turbo fit that piping or how well does it fit your stock piping if thats what you have ?
Had to modify quite exensively
5. What boost level are you consistently running ?
15psi
6. What model boost controller are you using?
cheap MBC
7. What EGT, A/F readings are you getting at those boost levels ?
A/F is usually between .85V and .88V, EGT yet to be installed
8. What other mods did you have to make in order to compensate for the extra flow and boost?
custom cat-back, header, K&N panel filter, DIY FCD
TD05
Saab 900
15psi
cheap MBC
Andy Rose
1993 Subaru Legacy Sport Sedan
2003 Subaru Impreza WRX
2004 Subaru Impreza WRX STI
1999 Hyundai Accent
1999 Hyundai Accent
rsstiboy
ciper wrote: The modifications on the recieving car are extensive though. I dont drive it as often, I usually drive my sedan to work. Probably the most interesting modification that is taking place at the moment is a high quality head job on the stock EJ22T heads and conversion to roller rockers.
if your not driving the car, and i'm assuming you'll be doing piston and conrod upgrades, why are you wasting your time with SOHC heads? you could get DOHC heads easily if you shopped around and they flow good enough standard, just get some eagle rods and CP pistons with DOHC heads with your 2.2ltr block whack on a nice big TD05 20G and you'll have a monster, obviously you'll need engine management, injectors, rising rate fuel regulator and a high power fuel pump, also parallel fuel rail conversion wouldn't go astray either
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
Age and treachery will overcome youth and skill!
MY99 2.5GT
No piston or conrod upgrades. Seeing the amount of abuse the OE parts can take I have no reason to spend the money on less stable aftermarket parts. I have yet to see any damage to stock EJ22T internals (from high power)
Dont even mention DOHC conversions. The money it takes to do such a conversion is far better spent on improving the flow of the original. Ive done more research than has been posted (lazy to type) and the DOHC heads dont automatically increase power. The difference I see is seperate timing control over the valves (which I have seen NOONE do). The DOHC have more rotating mass and friction, you end up loosing power. Besides I would need to create custom ignition wires to fit the center mounted spark plugs. It doesnt help that the DOHC heads available dont have the correct bore.
I havnt decided yet if I want to perform the parralel fuel mod.
