Finally I've got a one for myself
So I've got the beauty: http://www.onerussian.com/php/album.php ... os/Cars/1/ for 2k$ USD with 141k miles on it. Engine drives strong but I have mentioned 2 prominent problems during the first evening of driving it (I just bought it because I couldn't resist my nature...)
1. I know that break pads are kinda worn, especially the rear ones. So I'm going to replace them, but I've tried couple of 'hard' break attempts (tires are 70% new, seems to be evenly worn and pumped). If I press slowly but with increasing power - seems to break pretty well. If I press them repidly and hard - it slippers.... So I will check ABS fuse tomorrow (which as I understood might be the problem), can somebody answer simple question: would any light come up if such a fuse is dead? How to know for sure if ABS works? just if it doesn't slip nomatter how hard I press?
2. This is more disturbing. There is a strong rear noise, which starts around 5 mph (not loud) and strength/frequency of it proportional to the speed I would say. I'm afraid that it comes from the rear end, and from the middle of the body, so it must be differential
I'm from Phila but now in NJ. I think I should better take care about the car before driving it 100 miles to get home, where I have a good mechanic. Here I have some friends who can help me with lifts etc... Or may be I will stop at some service center so they lift it up and assess what 'they can fix', so I can drive away - can smbd recommend such a place around Newark?
Can you please give me any other hints on what to check to localize the sources of the problem? I'm kinda new in mechanics - just did whatever I needed to keep my nissan running (body work, change of head gasket, timing chane, crankshaft bearings etc) so I know that I don't know a lot - please help me!
Thank you all in advance for any help
