So after my intercooler hose blew off I started getting less and less boost. Now I don't even get positive manifold pressure!!
Made sure the my bov (with the crushed end) wasn't the culprit, so I took it completely out of the system. Plugged the two holes. No change.
Checked the wastegate. It would fully close and while the engine was still cold (and on) I opened up the wastegate slightly. Yup, exhaust gas would start leaking through the wastegate. I don't think that's the problem.
I have a cracked inlet tube into the turbo, but since that's pre-turbo I don't think that would be the problem.
So now I've gotta figure out where the restriction is? Would a boost leak small enough that it doesn't affect vaccum driving operation let off all boost?
I'm going to take off the intercooler again, check all vaccum hose listed in vrg3's post, and see whether that's the problem. Gonna check the turbo to see if it's not blown as well (freeplay, spins freely, etc). Anything else to check?
If the turbo's blown, I may have to take it to Extreme Motorsports for an 18G upgrade
