Engine very slow to return to idle
When I "blip" the throttle on my 91 Turbo 5spd, the revs rise quickly but they fall very slowly. This is annoying to me, and I was wondering if there is anything that I can do about it.
Thanks!
Thanks!
Is this after the engine has warmed up? That tends to happen much more when the motor is cold.
I can't tell you if what you're seeing is abnormal or not. The engine does take longer to slow down than most of us would probably like. A good solution appears to be a lightened flywheel.
When cold the ECU slows it down to speed warm up, but when warm it's most likele just the flywheel. Try the older Subarus if you want slow wind down.
Mine does the same thing. Doesnt matter if its cold or hot, and is intermittant. I know its not a flywheel issue, more like the throttle plate staying open. I oiled the cable, and throttle linkage, but to no avail.
My question is, is there a problem with oil building up inside the throttle body, gumming up, and making it stick? Or is it more likely an ECU issue, or possably TPS?
Id love to just pull off my throttle body, but with my intercooler, its eisier said than done.
Jus curious if any of you have any other ideas, so as to shorten my troubleshooting time
your TB pretty much isn't messing with your idle too much as long as it's closed. It's your IAC valve.
don't bother messing with your throttle cable. Check the throttle plate and stop screw around the TB. If it's closing fine, then it has nothing to do with the throttle area.
- quasi-mod-o
It does sound like the IAC valve isn't functioning smoothly. When you let go of the throttle it's supposed to open somewhat to act as a dashpot but it sounds like you're getting too much of that effect. I'd say try cleaning it.
bump.
After a track day my engine is doing this, when warmed up and is very annoying since I DO have a light flywheel and the RPMs should fall quickly.
I took the magnetic actuator off the IAC and I spun the knob back and forth, it seemed like there was a little stickiness at one end of the play, has anybody had luck taking it off and cleaning it?
Mine has an annoying tendency to maintain RPMs when I push in the clutch. It seems I have to wait an abnormally long time before the RPMs drop any.
Rio Red '91 Legacy SS
Well I found my problem:
The throttle cable somehow got tighter and wasn't allowing the throttle to close all the way. I loosened the nut that holds the throttle cable by the TB and released some tension and a test drive confirmed the fix.
This was after I spent a while messing with the adjustment of the IAC actuator, which is working just fine.
my car has this problem also. ive done a manual swap and my ecu still thinks its aan auto because i havent put a ground wire in one of the pins. (cant remember witch one it is). so my idle will sit around 1100 rpms almost all the time. some times even higher like 1500 or 2000.
im going to try cleaning the iac valve and see if it helps any.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
94 L n/a 5spd, Rip
satin - to avoid taking the whole fucker off which is a pain just take the white cap, the part the harness plugs into, off. If the knob under there can move back and forth easy then it shouldn't need attention.
