Where does the G in EJ22G come from?
ciper
Post by ciper »
Is it from the engine numbers like EJ22 GDW7PR ?
THAWA
Post by THAWA »
i believe so, my engine code is ej22e-something and its an ej22e engine
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
puckaveli
Post by puckaveli »
Correctamundo.
ciper
Post by ciper »
You sure? Can someone triple check please?
If that is in fact the case then I have something interesting. The number I gave in the first post was FROM THE ENGINE PLATE ON A 22B IMPREZA
boostjunkie
Post by boostjunkie »
LOL!
Ciper's really tryin to nail those nasioc boys!!
puckaveli
Post by puckaveli »
The short name of Subaru engines that people use comes from the engine type on the vin plate.
EJ20GDW5PR - Ver 2 type RA EJ20G
EJ20KDW6PJ - Ver 3 type RA EJ20K
EJ207DW1PJ - Ver 5 type RA EJ207
so on so on.
puckaveli
Post by puckaveli »
I read your post on Nabisco.
The turbo legacy and 22b share the same block, but the 22b didn't get the squirters. The legacy blocks with the squiters should have 2 crankcase breather tubes and the 22b has only 1. This is from Adam at Lateral Performance, he specializes in 22b's and is a moderator on 22b.com forums.
czo79
Post by czo79 »
hmm...interesting...doesn't the ej20g only have one crankcase breather as tube as well?
Micum
97 Legacy 2.5 GT - mod'd
93 Impreza L AWD (sold)
97 Legacy 2.5 GT (deceased)
98 Legacy Outback (sold)
rsstiboy
Post by rsstiboy »
the 22b has quad cam heads
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
ciper
Post by ciper »
You mean a quad cam engine with dual cam heads right?
boostjunkie
rsstiboy wrote:the 22b has quad cam heads
I think Ciper is referring to the shortblock being the same, not the longblock.
Matt Monson
Post by Matt Monson »
Ok,
*playing devil's advocate here* Then show me where on your Legacy it says you have an EJ22G? I seem to remember the plate on my recently sold turbo stating that I had an EJ22T...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Matt Monson
Re: Where does the G in EJ22G come from?
ciper wrote:Is it from the engine numbers like EJ22 GDW7PR ?
Oh, one other thing. The way you read an applied engine code is as follows:
E= engine
J= Flat 4 16 valves
22= division of displacement (2.2l)
G= division of fuel supply (in the 22B this is DOHC HP Turbo)
D= division of rebulation of exhaust gas (japanese domestic market)
W= division of transmission (manual)
7= division of year (1998, the Impreza began in '92)
P= division of spec difference (p=DOHC direct push, STI)
R= division of spec difference (R= power steering, AC, STI)
So, I hate to rain on your parade, but when you get back from the garage you will not be able to tell me that any of you have EJ22G's...
Suby Hai!
ciper
Post by ciper »
I think we need to double check on the source of "EJ22G" mentioned on this board before.
It may be coincidence that the block name is EJ22G and the Vin plate happened to have the same letters.
It would be like saying Wireless Access Points and Wireless Application Protocol must be the same because they happen to be related and share the same letters.
Matt, you should do a google and a nasioc search on EJ22G and see how the block is referred to as such very often.
Matt Monson
I don't need to search on google or NASIOC to see that people refer to the EJ22T as an EJ22G all the time. I even used to do so myself until I got properly educated in how Subaru names their engines. Just because they call it that does not make it so...
Suby Hai!
ciper
Post by ciper »
What would the proper short name for a closed deck EJ22 from a US Legacy turbo be then?
Something like EJ227?
Up until recently I always said EJ22T, until someone on this board posted over on Nasioc about the G.
rsstiboy
Post by rsstiboy »
US EJ22t
does that help identify what engine you guys have? :lol:
Matt Monson
ciper wrote:What would the proper short name for a closed deck EJ22 from a US Legacy turbo be then?
Definitely not EJ227
The numbers replaced the letters in the division of fuel supply gradually starting in '98. In '98 there were engines with the G and K designations as well as with the 5 and 7. The thing that is inconsisten is that Subaru used the G designation on the 22B even though it was an STI special edition. Only in the early days of Imprezas had both the standard WRX and the STI been tagged EJ20G. In '97 that changed with the introduction fo the STI vIII and the creation of the K designation for STI's. Then in the next two years, the Ej20G blocks(which had become open deck from '94 on) got rolled into the K designation as well. fortunately, with the introduction of the number Subaru has been very consistent.
a 5 in the division of fuel supply means a DOHC turbo MPi
a 7 in the division of fuel supply means a DOHC turbo MPi High Performance, aka STI. The USDM EJ22T is definitely not an STi high performance engine. :wink:
Suby Hai!
ciper
Post by ciper »
I want you to create or link to a full engine code descrambler please.
All this time I've been trying to impress chicks by talking about the EJ22G in my kitchen. Maybe this is why it hasn't worked yet. I knew I should've just called it a turbo!
puckaveli
Post by puckaveli »
You guys are making this more complicated than it really is. All you have to do is have someone with a US turbo Legacy look at their vin plate and put up the Engine Type in this thread and the problem is solved, no more discussion needed. I'll get the Engine type for the 22b's from Adam on 22b.com.
ciper
Post by ciper »
The first post has the number from a 22B engine plate, unlike others on the boards Im in direct contact with a 22B owner.
Where did the EJ22G come from is the question, from my original understanding it was a BLOCK designation, the EJ22GXXXX on the engine plate is a combination of the EJ22 and G meaning DOHC from what Matt posted.
puckaveli
Post by puckaveli »
Well I wouldn't be surprised if the US turbo legacy's have EJ22G on their vin plate. It seems Subaru has a tendancy to do that to the US market. My 2-door RS and most others are marked as a sedan, so go figure. Oh well just trying to help.
