mitsubishi TD05H?
mitsubishi TD05H?
does the exhaust flange on the mitsubishi TD05H turbo match up with the stock ss legacy exhaust?
92 legacy turbo 5spd fwd-12 psi, tm intercooler bov, walbro 255.
81 chevy malibu- 400 sb, holley 600, edelbrock rpm, hooker headers, lunati voodoo cam,4spd muncie, 3:73 posi,monte c. swivel buckets, corvette rally wheels
which subaru has the Tdo5h turbo, is it the wrx, i know that mitsubishi has the tdo5 in the eclipses i know it would be easier to find one of those than an wrx. so the eclipse ones wont fit?
no. it wont fit since the flanges are not the same, and i don't think they have the 90° helbow on the intake side.
i know the TD05 was on STI 1 and STI 2 WRX, was also on other WRX till 96, but for the exact date.. no idea. . you may want to check on the www.scoobynet.co.uk forum
morgie
'98 4Runner V6 Manual 4x4.
watch out if buying a 1996 Model year WRX Turbo. 96 was a strange year when they switched from using the TD05 to the smaller TD04. Apparently early model year WRX's got the TD05 while Late production ones got the TD04. 93 to 95 most definetly all rex's and STi's had the TD05.
Mark,
Mark,
NO turbo directly bolts onto the stock turbo location.
All the wrx turbos will fit onto the exhaust flanges fine, but NONE of them will completely work with the intake side without modification. Only the subaru TD05H will work with the stock intake tubing, however, the outlet of the turbo to the TB will NOT work with the stock turbo to TB tube. That's why if you're gonna get one of those turbos try to get it with the wrx/sti intercooler that matches with it. Makes install a little easier.
so i should only get a tdo5 from a wrx, not an eclipse, because only the wrx exhaust flanges match up to mine?
- Vendor
We sell the TD05H-16G brand new with a warranty if you are interested. Unfortunately at the moment we are out of stock on them but we include coolant supply hoses, oil return, and wastegate actuator. We can also port and ceramic coat it for you if you would be interested. Feel free to check out our website or send us an email at deadbolt@aol.com if we can be of service.
www.deadboltspeed.com
