Best place to get front and rear new rotors for a good prce?
Time came to replace my warped rotors. Any good places to get new front and rear's for a good price?
1992 Subaru Legacy L+
FWD
Automatic
FWD
Automatic
I'm not a particularly big fan of national chain stores but, typically, you can get pretty good deals at places like Pep Boys or NTB for that kind of stuff. Also, you get the added advantage of knowing that if they mess something up it's usually covered.
I've never had a problem personally, but most things related to brakes and the like I do myself. Go to Autozone, or if you're like me, the dealer and get "official" Subaru parts. Rotors aren't difficult to do -in fact, I can usually swap out a pair of rotors in about 30-45 minutes. I alway's recomend learning to do these kind off operations yourself. It'll give you the opportunity to not only learn about your vehicle, but it'll save you a lot of money in the long run.
Pick up a Hayne's or Chilton's manual, get yourself a decent set of tools and get to work.
Bob
90 Legacy LS AWD n/a -190,000 and going strong!
91 Legacy SS -currently stock and awaiting marginal upgrades (dead) RIP
Some people say to, but I don't bother as the two haven't coincided with replacement schedules and I haven't had a problem.
only problem with old pads, new rotors, etc.....if you use different pads after you have used the old pads to break in the rotor, you could end up with uneven pad deposits and more problems then it's worth.
I've replaced pads and rotors at the same time and had no problems. I've actually had LESS problems doing this, then just swapping pads....for the exact reason I mentioned above....the two brake pad materials didn't jive.
What ciper said, I thought for sure I'd need new rotors when I was doing my brakes a few weeks ago. But the shop said they were well within the limits and could be turned. This is a car that spent most of it's life in Steamboat CO, so the brakes have been punished...and then I bought it. They were slightly warped with all of the OE 200k mi on them, lot's of material to play with, even after being turned. So unless they are really bad or you need an excuse to upgrade
, you can probably have them turned.
Missing a 92 L Wagon, Enjoying an 05 RS Wagon
When I last bought rotors I picked them up at NAPA. I bought them in NH so there awas no sales tax and I think they were $30 ea for the front and $28 for the back. Why bother turning them they when are practically cheaper than the pad kit? Don't mess around with the brakes...Do them right!
1994 GT Wagon all stock with 375,000+ original owner miles
From what I've heard that is true, but in my case I still think they will out last the car. I've also heard that the effect/difference, like drilled/slotted/blessed rotors, is so minimal that most mere mortals can't tell the difference. If you are pushing hard enough(a good thing BTW) to kill a turned set, you probably shouldn't be running stock stuff anyway.
Until I got cryo rotors I would blow out the front pair every 6 months - severe pulsing.
i appreciate your responses guys. however, i've had my rotors turned once already and i'm not sure if this can be done again. i've called a few local stores such as pep boys, advance auto, mainline...etc...
at salvo i can get new rotors for 15.99 each which sounds like a deal. however, i think they are junk for that price especially since they are made in china. the brand is aimco and they have a 6 month, 6000 mile warranty. sounds like crap to me. i really need your opinion guys. should i get my rotors resurfaced if possible or buy these new $15.99 rotors?
thanks
thanks
FWD
Automatic
FWD
Automatic
