Just have a chance to get a whole set of rear 6 pieces control arm links, all links from WRX GC8, its in good price but will they fits to my BC5 without any modify?
Thanks for the answer.
Yep, I think it will be a good swap, since the car is about 12years old and the chassis and the bushing are tired so its time to do some change!!
Yeah, they are the same length, but the bolts on the FWD are different. It uses one long bolt on the inside holes for the arms, this bolt is too large to go through the bushing on the front pair of lateral arms. Though you can drill it out.
