A DUH!!! an IC hose epiphany Now with Pictures!
So I was cleaning ye old engine bay this morning and WHAM! it hit me The radiator hose!!!! it has the exact shape Ive been looking for. It might just work to connect my turbo to my WRX IC hose. It has the perfect S shape
Next time im at my Subaru dealership, or napa, ill order one or pick one up.
Im a genius
Edit: here are the pics!
Im a genius
:twisted::cool::twisted: "Plenty of time, to ruin my life, so why start now?" The Movie Life
1993 Sports Sedan, Exhaust, MBC, 02 WRX IC, KYB GR-2s...Now with old back seat!
Its ALIVE! the hose was slightly too small in diameter but I ended up getting it to fit with a lot of cursing and hurting myself. so far I did a few 11Psi hard pulls last night and drove down to denver today, the hose hasn't buged cause I clamped the hell out of everything. I hope the hose will hold up to the heat and pressure. Ill Get pics up when I get home.
All you guys that are using the radiator hose...
Are you only using it for the WRX intercooler?
Anyone found one that will work for putting a Saab 900 i/c on easily?
Rio Red '91 Legacy SS
i like that setup it looks good legacypunk555 nice clean with a nice touch. one think if you use rad hose, keep checking them cuz if oil gets on or in them it will make the melt stiffn crack the hoses oil can make a mess out of those rad hoses. i changed so many of them on my car, hot oil can cook anything.
Silver Sedan with a TurboXS sticker on the small rear window, the oil was another thing that concerned me, maybe Ill hunt down a silicone hose piece some day, but for now it's a HELL of a lot better than the loopy-de-loop system I had earlier.
Moved the igniter, pounded on the firewall a littlle, ditched the AC (although it might work with AC), Re-directed coolant elbow thing connecting to turbo, bent each side of metal part above engine mount so the y-pipe could fit better, mixed with a lot of sweat, blood and cursing.
IronMonkeyL255 wrote:All you guys that are using the radiator hose...
Yes but you need some kind of adapter plate for the WRX IC to use the Stock BOV, when I used a WRX BOV the car ran fine but a little rich and it was open atmosphere, but theres no way to plumb it back to the intake.
- Lurker-King
Another question
What Size ID was/is the Radiator Hose?
I bought a 1 1/2" hose today but it wouldn't fit...... well it would probably fit over the turbo but not over my inlet hose...
I'll probably go buy 1 3/4" with the same bends, napa has a book, I looked at them and chose the one I thought would work, indeed it would if the ID size was bigger.
R I P-------- 91 Turbo 4EAT --------R I P
Its the exact same hose as the upper radiator hose, it took a LOT of effort to get it onto the turbo outlet as it was kinda small, but i made it work, still not sure if my setup is 100 percent reliable though, so far so good, except my damn check engine light.
You can make one yourself pretty easily. I described the one I made in this thread:
http://bbs.legacycentral.org/viewtopic.php?t=18585
Awesome.vrg3 wrote:You can make one yourself pretty easily. I described the one I made in this thread:
