Thanks!
EDIT: Our prices and services are listed below.
I have a used one that I can sell for $45.00 shipped within the lower 48 states. I do not have an extra E-clip for it however, you can get that at advance or even a Subaru store for about 50 cents.LegacyT wrote:how much is a wastegate actuator for a TD05H 16G? I bought a 95 STI TD05 from the U.K for 150 USD shipped but it came with no wastegate so I need to get one. Also, what is the recommended mileage between rebuilds? The one I bought has 60K miles on it. Is it good for some time or should it be rebuit? Shaft spins freely and there is no wobble. Anything I should check over?
Mark,
I actually had someone mention the fuel rails in an email earlier so I am going to do some investigating on that as well. I have rebuilt a few of the TBird turbos, there does not seem to be a dramatic difference in the compressor wheels, I wouldn't think you would get a tremendous amount more power with that. We can put a wheel in the turbo that would be bigger than your current wheel and do a rebuild while we are in there.evolutionmovement wrote:I have a few questions/suggestions. How about a parallel fuel mod kit for the turbo engines?
Also I have a stock Legacy turbo VF-10 that I was thinking about doing the 'T'Bird' mod hybrid mod where the compressor of the '87-88 T-bird is added to the Legacy's exhaust. Would I be able to send that in for porting and check? Would it be a better idea just to have the standard turbo ported and polished? At some point I will get a better turbo, but I'm looking for around 250-280 HP with excellent driveability but would eventually like to be able to make 300 even if I don't use it (I like to use components under their limits when possible). The car will also have a air-water intercooler.
Sent you a PM.DLC wrote:I have a spare RHB52 turbo that i purchased with the express intent of having rebuilt to swap out the current unit i have.
I would be interested in a price for a rebuild, porting and ceramic coating. Any reasonable upgrades would be taken into consideration as well, e.g. larger compressor wheels, etc...
My travels through the web suggest that there is virtually no gain to be had from the "thunderbird hybrid" mod...DeadboltEnterprises wrote:I actually had someone mention the fuel rails in an email earlier so I am going to do some investigating on that as well. I have rebuilt a few of the TBird turbos, there does not seem to be a dramatic difference in the compressor wheels, I wouldn't think you would get a tremendous amount more power with that. We can put a wheel in the turbo that would be bigger than your current wheel and do a rebuild while we are in there.evolutionmovement wrote:I have a few questions/suggestions. How about a parallel fuel mod kit for the turbo engines?
Hmm... used VF30 exhaust housings can be hard to find. I may have something here that would work. If you can send me pics of the crack we may be able to repair it for ya. Our email is deadbolt@aol.comMatt Monson wrote:I have a VF-30 with a cracked exhaust housing. What would it run to replace that housing?Everything else appears to be in usable condition, but you never know until you guys have it in hand. But let's assume for now, it is just the housing...
