Don't know how to install light for boost gauge
madsubi
Post by madsubi »
Hey I really tried to install the light for my new boost gauge, but don't seemed to find the right cable to connect the 12V cable to... I ried the turbo timer.
boostjunkie
Post by boostjunkie »
Did you mean to say you fried the turbo timer? If you really want to do it ghetto, you can take the wire lead (for the LIGHTING of the boost gauge and slide it into the fuse insertion point for the interior/dash lighting (it should be marked in the passenger compartment fuse box in the left kickpanel of the drivers seat).
Slide the wire in and put the fuse in to hold it in place.
I hope you mean "tried" the turbo timer...
Where is your gauge mounted? If it's near the center console the easiest place to tap for lighting is probably the ashtray light. It's got a simple T-shaped connector. One wire will be floating when the lights are off and +12v when the lights are on, and the other will supply a voltage that varies with the dimming. See this page:
http://www.graphics.cornell.edu/~v/dimmer/
eastbaysubaru
Post by eastbaysubaru »
I used the cigarette lighter socket. I don't use the damn thing anyways except for my radar detector (which never leaves the car anyways). It's easy to get to and close to the A-pillar.
-Brian
'04 PSM FXT
rsstiboy
Post by rsstiboy »
i pulled the cover off my steering wheel boss and found the wire that turns the headlights on, i tapped into that one.
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
madsubi
I don't speak Japanese
Post by madsubi »
Hey guys thanks for your replies, my only problem with that fuse box is, that i can't read Japanese... well Ill try and find out.
1993 GT Legacy
Well, if they're the same as over here, this might be right:
Code: Select all
Fuse #  Current  Description
1       15A      Reverse lights, turn signals
2       20A      Wipers and washers
3       15A      Cigarette lighter, power mirrors
4        -
5       10A      Taillights, parking lights
6        -
7       20A      Rear defroster
8       10A/15A  Cruise control, ABS, airbag (15A on airbag cars)
9       10A      Dash illumination
10      10A      Height control
11      20A      Power locks
12      20A      Brake lights, horn
13      20A      Radiator fan
14      10A      ECU, TCU
15      10A      Gauges
16      15A      Ignition, airbag
17      15A      Radio
18      -/10A    Cruise control, ABS (only on airbag cars)
19      20A      ABS solenoid
20      15A      Blower motor
21      15A      Blower motor
boostjunkie
I could've sworn the underdash fuse box was in english. I know I can't read Japanese! :lol:
madsubi hasn't said where he's located, but his sig says the car is a 1993 Legacy GT, so it's probably not North America.
boostjunkie
Ah, I see.
MY92
Post by MY92 »
I tapped my backlit from the rear demister switch.
John
http://www.cardomain.com/ride/560635
aspect
Post by aspect »
I stole the leads from my emergency light flasher switch, cos I dont think i'd have much trouble finding it in the dark and now the boost gauge dims with the rest of the dash!
dirt-covered 91 SS prorally
pat richard roll cage, DMS 50mm, stickers...
SOLD :(
99 impreza RS
ver. 7 sti swap, ver. 6 RA suspension, JDM bodywork, rotated GT28rs
Cpt_chood
Post by Cpt_chood »
i am new here but, when i installed my boost gauge, i hooked up my light to my allumination connection for my radio, it comes on when the head lights and parking lamps are turned on and dims with the dimmer switch. just and option.
