rear endlinks on 92 awd
quicklook
Post by quicklook »
my rear endlinks on my 92 legacy ls awd do not look like the "c" looking ones in the catalogs. mine have a straight shock looking mount on bottom and a round mount on top, maybe about 5-6" long and perfectly straight.
anyone else have these?
also the pm messaging no longer works right , and i have tried to get a hold of some members, but no luck.
NuwanD
Post by NuwanD »
no sure about the pm situation, i have a 92 turbo and i have the drop links as well, instead of the c shaped endlinks... i believe subaru changed all models to the "C" style for 93 and up
Nuwan
1992 Open Class Legacy Turbo
2004 Forester XT
1990 Rover Mini 1000
BAC5.2
Post by BAC5.2 »
Are there any advantages to the C style?
ej22t
Post by ej22t »
If you wanna put the "C" style on ,you have to change the arm that could fit the "C"style end link.
Buy a new one from Dealer it just cost around $60 Cad for a pair.
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
Post by entirelyturbo »
Yeah I found that out when I bought what was supposed to be a 93 turbo rear swaybar. It has the endlinks, while my 91 has droplinks. I just decided I'm gonna get a 91 turbo rear swaybar, as soon as Opie gets off his butt and pulls it for me ;)
*Formerly DerFahrer*
mTk
no title
Post by mTk »
If you want to keep the same style control arms and uprade the swaybar, order the whiteline bar for 89-91 legacies from PDM-racing.com, it comes with upgraded endlinks like what you have.
MK
1992 BC672 AWD 5MT
what doesn't work with the pm? try sending me a pm.
greg donovan
Post by greg donovan »
so is there an advantage between the "c" style versus the older drop links?
my 90 has drop links and i want to put the whiteline lateral links on my car but they are for the "c" style endlinks.
if i get the lateral links do i need to change the sway bar too. or will the old sway bar accept the "c" endlinks
greg
