Removing Dash, any tips?
Hello, i'd like to get to swapping my beigetastic dash out w/ a black turbo one this weekend. Does anyone have any tips?
I just plan on removing/bagging/labeling all the bolts, nuts, and clips. Any idea if the dash can be removed and the car remain driveable? i may have to spread the work out over a few days.
MK
MK
1992 BC672 AWD 5MT
BAC5.2
Disconnect the battery! Seems like common knowledge until you forget and BAM air-bag in your face.
Wait... the 92's didn't have airbags, did they?
Then no, you should be good with everything.
I saw an Eclipse last week with no dash and he was driving. As long as you have the speedo and such all in place, then you should be fine.
They were an option in 1992.
I drove my Benz around for many weeks with no dash. The gauge cluster was ziptied to the steering column. The only working gauge was the oil pressure gauge.
Be patient when removing the dash. There are a lot of fasteners and you don't want to force any of them. Also, the wiring harness is clipped to the inside of the dash and must be gently unclipped. You may find it helpful to label some or all of the wiring connectors that you undo.
I don't know how well this stuff works, but have you thought of dying the one you have? Its very difficult to get them back in without geting a few squeaks and rattles in the end. I hate the beige, too, so I understand why you're doing it. I painted the beige dash of my old one with black vinyl paint. It scratches off, but looked OK. I don't recommend it.
LaureltheQueen
- Spelling Nazi
haha, yeah. Tan interiors in the legacies are REALLY ugly. I'd say patience is the key, i've never removed the entire interior, but the IS technically driveable without the gauge cluster, just not legal(i've done it)
on a sidenote, my 92 turbo doesnt have airbags
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
QuickDrive
- Lurker-King
If I can remember correctly it's not that hard.
I removed the dash in my 92 when I stripped it.
There are 5 major bolts holding it in place,
12mm if I'm not mistaken, 3 up toward the windshield and 1 on either side, left and right.
The rest of it is mainly trim pieces. Take all the trim off, deffinately take out the steering wheel. even the seats if you want to do it right with a lot of room.
Try and keep track of your screws mainly, they tend to pile up.
I think reassembly will be the harder of the 2. and I didn't reassemble mine so I can't help.
R I P-------- 91 Turbo 4EAT --------R I P
Matt Monson
- quasi-mod-o
I did the majority of this today in preparation for rewiring the car for the swap. It took less than 2 hours. I didn't encounter any clips other than two on each trim piece at floor level. Everything else was phillips screws ot 10mm.
But it is not out yet. I encountered one problem, that I was actually reading through threads to find an answer. Does anyone have a trick to remove the steering wheel in absence of a steering wheel puller? I don't want to go buy yet another one time use tool just to get the damned wheel off...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
I have swappe out my dash finally. It was not hard at all. I also replaced the heater core with one i had from my 90 parts car.
Like matt said, 10mm bolts, and phillips screws, except for some ground wires that were attached to the body (12mm bolts).
matt: other than hitting it with a hammer, maybe using a tie strap attached to the steering wheel and then around the b pillar. Ratchet the sucker and see if the wheel pops off
MK
MK
1992 BC672 AWD 5MT
Matt Monson
- quasi-mod-o
Can you suggest a way to get the dash off with the steering column still intact?jake15 wrote:why do you want to remove the steering wheel? if u dont mind me asking.
Suby Hai!
Suby Hai!
use a steering wheel pullerMatt Monson wrote:Can you suggest a way to get the dash off with the steering column still intact?jake15 wrote:why do you want to remove the steering wheel? if u dont mind me asking.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
I got a cheap puller for ~$12. I'd lend it to ya if you were closer, but buying one would be cheaper than the shipping.
unbolt the steering column. it has 2 bolts that hold it to the gray thing the computers are on. after you unbolt it it will just lay down out of the way. or if u have an adjustable steering column u can put it all the way down and lift up the dash, i think that worksCan you suggest a way to get the dash off with the steering column still intact?
LaureltheQueen
- Spelling Nazi
LaureltheQueen
- Spelling Nazi
Matt Monson
- quasi-mod-o
LaureltheQueen wrote:oh... the entire dash.... I get it now...
Suby Hai!
Suby Hai!
i'm not talking abour removing the whole steering column... just unbolting it from where it bolts in the car, it lays down out of the way and u can take the dash out. and u dont have to pull the wheel, and u can just bolt the steering column back in when the dash is out and u can still steer just in case you need to move the car.
