Im going to be doing a tuneup soon on my EJ22T. I know to use NGK plugs, but what should I gap them to? I have a diamond coilpack and 7.5mm magnacore wires. If anyone can tell me the stock gap that'd be great.
Timing... Ignition timing Can it be adjusted? If so, what is stock and where should it be for optimal performance? What is it that controlls the ignition timing as well?? is it the ECU?
Im not looking for a huge increase in power, but just a more comfortable power band.
The manual specifies a gap of 1.0 to 1.1 mm (0.039 to 0.043 inches). If you get NGK plugs whose part numbers end in "-11" they will be gapped from the factory at 1.1mm, so in all likelihood you won't have to adjust them. You should still definitely check each plug though.
You can't adjust ignition timing. It's completely controlled by the ECU.
I was talking with Steve (cant pronounce his board name) today and he was talking about an Apex-i controller that tapped into the ECU and took over the ignition. I see there's notches on the crank with numbers, so i assume you can check the timing. I havent done so yet though.
Now that I have a AWIC to play with, i want to make sure everything else is in order before I start toying with boost. Also, i need to see if my coffee cup will work
I run a 0.8mm gap but then again I run 18psi all day every day.
MY02 B4 Liberty, 2 1/2" off the primary with splitter, 3" off the secondary, 3" the rest of the way, completely stainless, k&n filter, ECUtek 3, 500HP walbro, 173kw@all4
Yes; higher boost means the mixture is more difficult to ignite and so with the same spark voltage you might need a smaller gap to get combustion to happen.
I also run 4 bosch HEC716 coils, from a 5ltr V8, and the V8 only uses 1 of those coils, I have plenty of spark
