Blacking Out Chrome Strip
QuickDrive
Lurker-King
Post by QuickDrive »
R I P-------- 91 Turbo 4EAT --------R I P
Looks nice!
How hard is it to change the handles?
QuickDrive
Lurker-King
The rear doors are a joke.
Remove the inner panel peel back the vapor plastic and remove two nuts holding the handles on.
The front on the other hand.
Same process for removing, except the rod that connects to the handles is the biggest pain in the butt to re-attach.
The smaller the hands the better in this case. I managed, but my hands hurt right now.
I also learned that the butter knife makes an awesome tool for working on doors. I used it more than anything else.
nzKAOSnz
Post by nzKAOSnz »
Hmmm. Reviving threads again - has anyone deleted that strip completly? (i.e removed then bogged over it)
Im thinking bout getting a respray.... that could be on the list.
***ITS CLEAN! :D*****
Armcomdes
Re: Blacking Out Chrome Strip
Post by Armcomdes »
rmorriso wrote:I've heard of people blacking out the chrome strip on their 92-94 legacys, but I'm not sure what paint I should use to adhere to a chrome surface. Any recommendations?
I own a 1991 Turbo where the black on the chrome chipped off, especially above the doors. Go to a sign shop that uses outdoor vinyl for lettering. The one I went to had different finishes of black vinyl (from matte to shiny finishes). Ask to buy some long thin strips and then apply it right over the chipped paint. I used shorter strips, so there is a seam. But the long strips would look better. Since it's outdoor sign vinyl, it holds up really nice. You can't tell the difference between the paint and the vinyl unless you look real close. It's pretty inexpensive, looks great and will last a long time if done right!
1991 Leagcy Turbo – Mica White
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
you cant really remove the black moulding strip without doing lots of bodywork. If you look, it wraps around directly under your tails, and is attached to the rear bumper. When I was planning on doing alot of body work on my 91L I considered it, but changed my mind due to that factor
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
climbingjunky
blacking out my chrome
Post by climbingjunky »
Well today i spent all afternoon blacking out the chorme on the trim of my 93 legacy. I have to admit that i like the blacked out look much more than the chrome. I also blacked out the grill with the exception of the subaru logo, and the trim that is just under the windows. If you plan on trying this i would highly recommend using Duplicolor Trim paint. The stuff dries very evenly and is ment to be applied to trim so it is very durable. I am planning on repainting the upper trim around the windows with a higher gloss Duplicolor trim paint, because like most legacys of the early ninties the paint is chipping and chrome is showing through. Plan on spending three to four hours working on this kind of project. Bail out the steel wool and acetone and do it right. here are a couple of photos.
Side view before blacking out
http://photos1.blogger.com/blogger/522/ ... 0_1924.jpg
View of grill before blacking out
http://photos1.blogger.com/blogger/522/ ... _19301.JPG
View of grill after blacking out
http://photos1.blogger.com/blogger/522/ ... _19511.JPG
Side view after blacking out
http://photos1.blogger.com/blogger/522/ ... 0_1952.jpg
LaureltheQueen
Spelling Nazi
Spelling Nazi
holy broken photos batman!
The place where you're hosting the pictures won't allow hot-linking. So you'll have to copy and paste the url into a browser window to see them.
islander
Re: blacking out my chrome
Post by islander »
climbingjunky wrote:Well today i spent all afternoon blacking out the chorme on the trim of my 93 legacy. I have to admit that i like the blacked out look much more than the chrome. I also blacked out the grill with the exception of the subaru logo, and the trim that is just under the windows. If you plan on trying this i would highly recommend using Duplicolor Trim paint. The stuff dries very evenly and is ment to be applied to trim so it is very durable. I am planning on repainting the upper trim around the windows with a higher gloss Duplicolor trim paint, because like most legacys of the early ninties the paint is chipping and chrome is showing through. Plan on spending three to four hours working on this kind of project. Bail out the steel wool and acetone and do it right. here are a couple of photos.
I would like to see these pics. Let me know if you need some place to host them and be able to link them. I'm subscribed to this thread so just post you answer here.
The stock pic works. :lol:
When I painted over my chrome strips, I used two grits of sand paper, then a grit/grime cleaner, then 2 light coats primer, 3 light coats paint. Similiar treatment for grille.
The paint came from Home Depot, nothing special.
The resulting thickness has helped prevent any chips so far (5 months).
climbingjunky
whoops sorry about that forgot about the no hotlink deal with blogger here are new links that should work.
Stock Side view
http://www.Climbingjunky.com/photogallery/100_1924.jpg
Stock Grill view
http://www.Climbingjunky.com/photogallery/100_19301.JPG
Blacked out grill view
http://www.Climbingjunky.com/photogallery/100_19511.JPG
Blacked out side view
http://www.Climbingjunky.com/photogallery/100_1952.jpg
1993 Legacy L sedan
-Blacked out trim and grill
-DIY grounding kit
-Ground Control Coilover conversion
-GR-2 Struts
-De-snorked
-My Dream: Install an Eaton M62 Supercharger.
islander
Post by islander »
climbingjunky wrote:whoops sorry about that forgot about the no hotlink deal with blogger here are new links that should work.
Stock Side view
Stock Grill view
Do you have modified pics from a little more far away? Better yet a 3/4 pic.
I wish my paint were in the same condtions as yours.
climbingjunky
will have to take a couple more pics tomorrow. Today i took the two front door pannels off removed the speaker covers, ripped the fabric off of them and painted them black. I did the same to the speaker covers in the back. I also removed the window vent on the top of the door pannel and the door handle inset and painted both of those black. Believe it or not, the removal of the fabric on the speaker covers seems to have made my sony 6 1/2" 's sound a lot better. It sounds as though the fabric really dampened the high pass sound. I will post some pics of these improvements tomorrow.
1993 Legacy L sedan
-DIY grounding kit
-GR-2 Struts
-De-snorked
IronMonkeyL255
Post by IronMonkeyL255 »
I did the same thing earlier, at least with the speaker covers.
Rio Red '91 Legacy SS
climbingjunky
here is a 3/4 photo of the blacked out trim.
http://www.Climbingjunky.com/photogallery/100_1950.JPG
1993 Legacy L sedan
-DIY grounding kit
-GR-2 Struts
-De-snorked
IronMonkeyL255
I got a can of bumper trim black paint for mine.
Now it just needs to stop ****ing raining.
