Parking brake adjusted to limit. It's not enough...
I've adjusted my parking brake stroke, and it does not quite reach the spec in the owners manual. It is supposed to tighten in 7-8 clicks. I go 9+ clicks and if the car is on an incline, the brake can just barely hold it. The adjuster is at it's limit, no further slack can be taken up.
Do I have to replace the parking brake shoes?
Will replacing the rear rotors help?
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
03 Legacy L Wagon
- quasi-mod-o
You could try adjusting it at the brake handle, but good luck - I couldn't get the nuts to move for anything.
That's what I did already. When I bought the car I doubt the handbrake was doing anything at all. I adjusted it using the locked nuts under the arm rest. You have to use two wrenches because it is two nuts tightened against each other to lock the adjustment.evolutionmovement wrote:You could try adjusting it at the brake handle, but good luck - I couldn't get the nuts to move for anything.
So... brake cable, eh? Do the seats and carpet have to come up?
-steve-
03 Legacy L Wagon
03 Legacy L Wagon
Did you adjust them at the back, then? There are little star wheel cylinders under oblong rubber covers on the hub backing plates. You stick a screw driver in to either loosen or tighten the shoes. I forget which way to turn, but it might give you just enough to get the brakes to hold.
